There's not much too it. Hose comes up from the bottom of the fluid tank in the backside of the front left wheel well, goes into the hood on the left side, connects to the two nozzles mounted on the hood. Open the hood and run the washer, is it draining out of the hood around the left or right nozzle set. It's literally just those three parts.
You don't really say, do you get a normal spray on the windshield, you just also get this leak at the hood? Or are you getting no spray onto the windshield? If the former, there's either a leak in the cable, in the nozzle assembly, or at the join between the two. If the latter, then the nozzles are clogged.
