Results 1 to 15 of 15
    Active Member Two Rings Riterbr's Avatar
    May 14 2018
    1999 Silverado
    WI, USA
    Supercharged Badge Installation
    Starting this thread because I couldn't find my answer elsewhere:
    What have you guys used to mount badges to you car if it didn't come with adhesive? I'm looking at buying a used set of Supercharged badges instead of shelling out $120 for the pair. I'm currently looking at the 3M VHB Tape, but does anyone know what is used on the OEM ones? I'd rather use OEM installation methods, if possible.
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Quote Originally Posted by Riterbr View Post
    Don't know if it's specifically called "VHB", but it's definitely 3M double sided badge/emblem adhesive tape.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Senior Member Two Rings mysteryman047's Avatar
    Feb 06 2007
    Cars and stuff.
    York, PA
    The 3M double sided works great as long as you prepare the surfaces first. Only thing I've found is that the OEM badges usually have a thinner version pre-applied than what you would buy in most auto parts stores.
    Senior Member Three Rings Dash's Avatar
    Jun 07 2012
    St. Louis
    VHB is short for Very High Bond.
    Veteran Member Four Rings Solarsuplex's Avatar
    Aug 20 2011
    Seattle Wa
    As said above, lots of badges come with an adhesive on them already.
    -James
    F T W L T B D W I C T W
    Moonlight Blue - B8.5 S4
    Brilliant Black - B7 A4
    May 14 2018
    1999 Silverado
    WI, USA
    Quote Originally Posted by Solarsuplex View Post
    I am looking to buy used badges so I don't have to spend the $120 for brand new. They would not come with adhesive, as they have been previously installed.
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    I used the 3M double sided badge adhesive that I got from my brother in law who does auto body work .Had previously used the same to adhere a spoiler on my Lexus. FYI there is a mounting template available to be printed on the ECS Tuning website .Heaven forbid that you don't put it in the exact correct place
    Mar 05 2016
    I got a roll of 3M double side adhesive from Walmart, it look exactly like the OEM ones.
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Yes, but if that is not strong enough, the OP will lose the extra 5 HP he gets from installing the SC badges!
    Apr 04 2012
    MSP
    You will also need the template to place it correctly on the car.
    http://bd8ba3c866c8cbc330ab-7b26c6f3...placement2.pdf
    Mar 28 2016
    Quote Originally Posted by MrFunk View Post
    This x1000
    Jul 02 2013
    Quote Originally Posted by Dr GP View Post
    .....Heaven forbid that you don't put it in the exact correct place
    and risk the almighty wrath of AZ members!
    Veteran Member Three Rings ElectroMike's Avatar
    Apr 17 2009
    2014 S4 M/T
    Exit 160 NJ
    I used the 3M double sided badge adhesive that I got from my brother in law who does auto body work.
    That's exactly what I was going to say, find a local autobody supply store and purchase the needed section of d.s. tape.
    2014 S4 - Glacier White Metallic | 6MT | Rear Sports Diff
    Unitronic Stage 3 | KMD Tuning S/C Pulley | Unitronic Crank Pulley | 3.2 Pulley ratio | Charge cooler system - Revo HX & AWE ColdFront Stand alone Reservoir | ECS - Kohlefaser Luft-Technik Intake System | AWE Touring Exhaust | AWE Resonated DownPipes | CR-15
    Established Member Two Rings Robstar's Avatar
    Jan 21 2015
    2014 S4 / 2009 A4 / 2004 Ducati 999s
    Bringing this post back from the dead.
    Im shopping around for 3M vhb adhesive. Im finding that the product comes in some various thicknesses. Ive also read here in some search results, that the product thickness im looking for would be on the thinner side.
    Im going to be installing some used supercharged badges. To my knowledge, the back side of the badge, is sunken in a bit from the outer edge of the badge.
    So my question to any of you who may be of assistance is, what would the best thickness of VHB tape be for this specific application to achieve the best flush results?
    My educated guess would be 1mm (ish) or .04" (ish) thick......without having the badges in my hands quite yet.
    Thanks in advance.
    Jan 21 2015
    This is great, thank you.......would anyone know if I can print this to scale on 11x17?
