Results 1 to 9 of 9
    Mar 12 2017
    N.C. USA
    My new 2016 Q5 plus tire question.
    Just took delivery of my Q5 yesterday w/22,500 mi on it. Drove about 200 mi to get home. Very nice ride. Well equipped w/ Premium Plus & Tech Pkg. Metallic white w/ beige. S.C. car all it's life so perfect condition.. Very pleased with my trip home.
    Tires (oem) are more than 1/2 worn. Thinking of replacing w/ Conti LX20. Had them on previous ML. Factory size is 235/60/18. Do not want to chg wheel size. What do you think of either 245/60/18 or 255/55/18? Will they fit & clear bodywork? How much will this chg the ride /handling ?. Or should I stay w/oem size? Any other recommendations?
    ALL coments appreciated.
    2020 Q5 prem plus Matador red/Beige
    Veteran Member Four Rings VroomVroom's Avatar
    Jan 03 2007
    SF Bay Area, CA
    Congrats on the new machine. What's your motivation for exploring different sizes? Is there something you don't like about the 235/60?
    From the driver's seat I'm not sure you'll notice a difference in either of the two alternatives. I suspect they'd both fit fine. The 245/60 will be a bit larger in diameter while the 235/55 shorter, with corresponding mild impact to speedo/odo readings. Because of the larger contact patch, you might see a barely perceptible decrease in fuel economy, and you might save three or four feet in a panic stop. Personally, when it comes time for replacement I'd stick with 235/60.
    --Jerry || 2020 SQ7 Pr, GW/Black/BO (His); 2018 S5 Cab Pr, Daytona/Red (Hers)
    Suspension || H&R Springs - 29001-3; Bilstein B8 Dampers - 24-145985 (F) & 24-145992 (R)
    Wheels & Tires || BBS CI-R - CIR 0501 BPO, 20x10 ET25 Satin Black; Continental DWS06 275/40
    ...Formerly: '16 SQ5 '13 Q53.0T '12 Q5 3.2 '08&'06 A4 Avant 3.2.
    Mar 12 2017
    N.C. USA
    New Tires.
    Quote Originally Posted by greasykid View Post
    Planning on keeping the oem 235/60/18 size & replacing w/CONTI LX 20's. THX. Anyone else?.
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    My '17 Q5 3.0 TFSI came with the 20" summer tire package with 255/45/20 tires. I'm not suggesting you buy new wheels. But the 20" wheels easily support 255 width rubber. The question is what maximum width will your current wheels support?
    If your wheels can handle the width and there is a aspect ratio that gives you the correct height for the 18" rims, you will really see an improvement in handling by going to the 255 width.
    I'm thinking that 255/55/R18 would be within one tenth of an inch of the same height, if your rims can handle it and there is a good tire choice available. There are tire gurus here who can help you in dealing with tires and rim sizes.
    Conti's DWS All season is available in 255/55/R18. It is a better, more performance oriented A/S tire than what you are looking at, but also costs more. They have a very good reputation.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Veteran Member Four Rings Das Ponto's Avatar
    Dec 20 2012
    2022 Q7 S-line
    Edmonton, AB
    Upgraded my 13' Q to 275/40/20's and man the handling and grip is next level.
    But that required a 20x9.5 wheel to run those. I know guys push to 295's as well with a wide enough wheel.
    Ponto
    2020 Glacier White A4 Allroad | 034 Dynamic Springs | 034 Intake | Unitronic Stage 1+ | Rotiform SGN
    2022 Daytona Grey Q7 | Quattro Magazine's Project Q7 Offroad | H&R Lift Springs | Black Rhino Volls | BFG KO2's | Rokblock Mud Flaps
    Instagram: Dasponto | Flickr
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    Yep. . .255/55/18 is the size you want.
    Mar 12 2017
    N.C. USA
    Q5 tire size question.
    Quote Originally Posted by SQive View Post
    My tire guru says that 255/55/18 will fit. Same diameter as stock 235/60/18. What about possible tire rub when turning? The 255's are 1 inch wider than the stock 235's according to TireRack. If I go any further it will be to H&R sport springs. Have put H&R springs on 2 previous SUV's---MB ML & Q3. Great results with very little chg in ride quality. Has anyone gone with the 255/55/18? LET ME HEAR FROM YOU. I am 85+ & just want to still have some fun. Only drive 6-8000 mi/yr. Keep the comments coming.
    Senior Member Three Rings KillerQuattro's Avatar
    Dec 15 2016
    Englewood CO
    I did 255's on my stock Q5's 19's for my winter setup. Not sure what the difference in offset is between the factory 18's vs 19's but I loved the upgrade to 255 for sure, and they fit just fine.
    Current: 1995 urS6 Avant. RS2 manifold, Stage 1 chip, Apikol FMIC, custom exhaust.
    Sold: 2013 Q5 3.0t- EPL Stage 2, 183mm CP, KW Coils, Eurocode Alu Kreuz, 034 inlet/AWE filter, EBC Brakes w/ SS lines, Hartmann HRS6 20x9, MF #11385 (center res) and Vibrant Ultra-quiet resonators out back.
    Sold: 2007 Ibis Avant- 2.0t 6mt, JHM HFC, TT DP, JHM HPFP, GFB+, B5 perch mod, 19x9 RS6, Hawk slotted rotors and performance pads.
    Sold: 1992 urS4- Garret 3071R, 034 tuning, RS2 goodies, 993TT BBK
    Apr 26 2014
    DFW
    Those stuffing 295/30/22's in there have the same wheel wells as you.
