Results 1 to 12 of 12
    Oct 18 2014
    Sherman Oaks
    C7 A6 3.0T Catalytic Converter replacement
    Hi All,
    It appears to be that my cats are going bad on this car and Audi is quoting me about $2500 to replace them. (In fact, that might have been labor, not sure)
    Needless to say, does anyone know if I can go aftermarket cats? I’m getting a CEL because of the cats. Car drives perfectly fine outside of this.
    Senior Member Three Rings John_Kaufmann's Avatar
    Dec 29 2017
    North Central Illinois
    Go to an exhaust shop and see what they quote you. Sounds like you are getting screwed. Might as well upgrade your whole exhaust system for that kind of money.
    Sent from my Lenovo TB-8504F using Tapatalk
    Senior Member Two Rings goliath1's Avatar
    Apr 13 2014
    custom built softail
    RI
    Way overpriced
    2016 S6 Mythos Black Metallic, B&O Sound, Sport Package, Driver Assistance, Comfort Seating, Black Optics, Audi Exclusive Interior.
    My wife said its golf or her, gosh I'll miss her!!
    Jan 03 2018
    South Carolina
    I have a OEM set with less than 25k on them
    2014 S7
    2012 Oolong Grey A7 | DP 91-104 tune| Merc Hx| 57/187mm| Cat delete| Magnaflow x-pipe| ported SC TOTALED
    Veteran Member Three Rings jrsAudiA6's Avatar
    Oct 11 2011
    2018 A5 SB
    Riverside, California
    The 2 cats thru audiusaparts.com are $711.29 ea. This price is for 2013 A6 3.0T. Just made a guess since you did not indicate year of A6. List price is $883.58 ea. So, $2500 to replace the them is probably reasonable considering the labor rates here in CA. Probably could get 10% off there list price or buy online and have trusted shop remove and replace.
    Just out of curiosity how many miles on your A6?
    2018 A5 SB Matador Red Premium Plus
    2012 A6 Garnet Red, Prestige Pkg, Innovation Pkg, B&O, 20" Sport Pkg, H&R RSS + Coilover, Alcon Mono6/380mm front brakes, S6 rear rotors(356x22mm)/caliper carriers.
    034 DL fr suspension arms, 034 Track DL engine mounts, Eurocode Front and Rear sway bars & Alu Kreuz front brace, 034 ECU/TCU tune, DP PR 3.11, JHM Hx
    CTX 50% Tint F. S. Windows, CTX 30% Tint R. & R. S. Windows, 3M Pro PPF, hood, L & R fenders, AWE Exhaust w/o down pipes
    Veteran Member Four Rings JWebb_C7_Comp's Avatar
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    Quote Originally Posted by Smeag OL' View Post
    Hi All,
    What year/miles. Aren’t CATs covered under emissions warranty for an extended period?
    Dec 29 2017
    I like where you are headed - There shouldn't be a C7 on the road with rotten cats even in the rust belt of Michigan and Wisconsin..
    Quote Originally Posted by JWebb_C7_Comp View Post
    Oct 18 2014
    Sherman Oaks
    Thanks for the information guys. Apologies for leaving out important details, the car is a 2013 and my road warrior with 105k on the clock now.
    Does anyone know how long they are covered under emissions warranty?
    @jazzyjay, PM price?
    Sidenote - I’m also being quoted $800 for two new headlight bulbs, ha
    Oct 11 2011
    2018 A5 SB
    I believe the emission warranty is for 7/70K miles, were as the federal emissions warranty is for 8/80K. The CA warranty covers more parts than the federal but in either case you are out of warranty.
    Sep 20 2017
    Northern Florida
    TBH I had a similar situation and just installed O2 spacers on my cats. They can also try updating the ECU at the dealer since the updated one has a higher threshold for the actual CEL for catalytic efficiency.
    Junior Member Two Rings
    Nov 21 2016
    North Hollywood
    Any update on this? My passenger side CAT is bad and leaving the loudest exhaust leak near the engine bay and slower acceleration. I have 137k+ on the dash so I want a simple fix by either removing both cats or fixing one.
    Labor alone to lower from engine is about a 6 hour job at $150/hr.
    Let me know why your fix was. Thanks!
    Jul 15 2016
    Michigan
    If you go to a knowledgeable indy shop labor should be in the 850 to 950 range. You dont need to drop the engine.
