Some background first.
Car was throwing P0342 - Camshaft Position Sensor Bank 1 circuit low. I did a quick check of the wiring harness and voltages (12v and 5v) were both good, as was ground. Figuring it was the sensor I ordered a OEM Bosch sensor and installed. Still threw P0342.
After a little more digging is appeared the charging system might be the culprit if diodes were going/gone and RFI was running rampant. I had the charging system checked and the first place could not check due to "noise" which would back up the RFI possibility. I took it to another shop, with better diagnostic equipment and verified that loaded the alternator was only putting out 12.7v so I ordered a Bosh Reman unit. Installed it. Getting good voltage now but still have the same P0342 code.
Decided to check wiring/connectors again. This time I unplugged the bank 1 sensor and checked everything with the car running. Previously with the ignition in the "on" position I read zero resistance to ground on the connector pin. With the car running I get 35-50 Ohms resistance. I also get .055v on the ground pin of the connector, where there was zero with the ignition in the "ON" position.
The Bentley manual shows the ground as '220- Ground connection (sensor ground), in engine compartment wiring harness'.
Anyone have an idea where that wiring harness ground is located?
Thanks in advance.
