I was wondering if any tech experts or experienced builders could share their thoughts and knowledge on this topic. Especially any experience with the 2.7 liter engine.
If changing for example only rods (from stock to like either Pauter (lighter) or IE (heavier)) then what has been the actual measured difference when unbalanced (the first balancing machine reading before the crankshaft counterweight machining).
From what I´ve read, if the weight difference per rod is in the range of 10-30 grams,
was there alot of balancing work needed? Or was the result still within a certain limit?
I´m planning a build, but an access to a qualified machine shop for this purpose is difficult. So just wondering about others experience with this work
