Results 1 to 13 of 13
    Jun 21 2018
    Anaheim, CA
    Issues with launch control
    Hey hey. So I have read the manual and watched numerous vidyas, but I can’t seem to get the launch control to reliably activate all the time.
    I wait for engine oil temp to warm up, turn off auto-stop/start, disable traction control (single push), put it in sport mode (also tried without this step), ensure steering wheel is straight, then push in the brake fully and then foot down on throttle. I usually feel the car urge forward a bit with RPMs hitting ~2k....more like brake boosting. Rarely the car will properly activate launch control where the revs hold ~3k until I release the brake.
    Anyone else experiencing this? Am I a special breed? Help!
    Jun 28 2018
    Augusta, GA
    The only thing I could possibly think of that I do differently is put it in dynamic mode. Never had an issue with launching following those steps.
    Jun 21 2018
    Anaheim, CA
    Quote Originally Posted by Alexdsheff View Post
    I have tried that too.......still can't get it to reliably engage :(
    Established Member Two Rings sbell008's Avatar
    Jan 27 2018
    Minnesota
    I've had this issue too, and it stemmed from me not holding down on the brake hard enough. It may seem like you are, but try it with a little more pressure, and see if that will get you more consistent results!
    Jun 21 2018
    Anaheim, CA
    Quote Originally Posted by sbell008 View Post
    I'm at work now, but will try after the car warms up on the drive home. How hard are we talking here? The pedal only goes down so far........
    Jan 27 2018
    Minnesota
    I'd peg it at slightly more than you might be comfortable with?
    Veteran Member Three Rings VipinLJ's Avatar
    Nov 23 2016
    Illinois
    Launch control works flawlessly for me. You have to put all the pressure u can on your brake pedal. Mine almost goes down to the floor.
    2018 Audi SQ5 Prestige - Matador Red, DAP, S Sport pack, 21” V design, CWP, WWP
    2017 Audi A7 Prestige - Glacier White, DAP, Sport pack, 20" BOP, CWP
    2020 BMW 330i xDrive
    Senior Member Two Rings DJPardy's Avatar
    Dec 19 2012
    2024 SQ5
    NH
    WE HAVE LAUNCH CONTROL IN OUR A4s???
    --Now Driving-- B9.5 SQ5 /////////B5 S4 /////////B8 S5///////// 8V S3/////////
    Nov 23 2016
    Illinois
    Quote Originally Posted by DJPardy View Post
    In the B9 A4/5/Q5 yes. It isn’t just brake boosting. It’s a proper launch control.
    The B9 S4/5/SQ5 don’t have it.
    Established Member Two Rings chavez885's Avatar
    May 06 2014
    Concord, CA
    Quote Originally Posted by VipinLJ View Post
    That's nuts I wonder why no launch control for them, just tried it yesterday and it worked easily.
    Turn off traction control
    Turn off auto-engine off crap
    Put it in Dynamic SPORT mode (drive mode doesn't work)
    Smash brake pedal hard to floor (it will go down pretty far)
    Smash gas to floor
    release brake pedal after a couple of seconds
    vroom vroom
    2019 Audi RS5 SB Glacier White Stek Matte Wrapped | ECS CAI, 034 E85 Stage 1 Tune, 034 Stage 2 Trans tune, IE Intercooler |
    2024 Audi Q5e | District Green
    Dec 22 2017
    2017 Sante Fe
    Farrell
    Never had an issue. Never had to smash the brakes either. Be sure to hold the traction control button long enough to turn everything off which happens in two stages, watch the info center, and have it in sport mode prior.
    You do have to brake past the point of auto stop. If you didn't know, you can prevent autostop. Just be soft on the brakes while stopped. Play with it, you will see what I mean.
    Sent from my SM-G950U using Tapatalk
    Hello Ms. Lady, I Brennan's brother and I think I can help with the Pam Pan thing.
    It's Pamm with two M's.
    What if I want wings? It's not enough Dad!
    Keep it real pony boy.
    Jun 28 2018
    Augusta, GA
    Quote Originally Posted by PamWith2M's View Post
    TC doesn't need to be off. TC sport (one click) is just fine.
    Edit: now that I'm thinking about it, I've always punched the gas hard to the floor, past the little stop you get. Requires just a little bit extra force to pass that point.
    May 06 2014
    Concord, CA
    Yeah also found out if you don't launch in time the launch control drops the RPM's back down to save your brakes. Oops
    There is definitely a sweet spot on the timing where boost is fully built vs just taking off at higher RPM and low boost.
