Results 1 to 17 of 17
    Nov 28 2017
    Carbondale, IL
    How much to trust MMI oil level indicator?
    I just picked up a '15 S4 last week and did an oil change last night. The MMI had indicated that the oil level was topped off before the oil change, and when I drained it, what was probably 9-9.5 quarts came out. (I have a 10-quart pan that would be almost to the brim when I did an oil change on my E60 M5, and it was pretty close to that level when I drained the S4.) I poured in 8 quarts, ran the car for a bit, and then checked the dipstick (yes, the PO retrofitted one). The level is onto the word that was MAX on the dipstick, so if I trust the dipstick, the engine is a little bit overfilled. However, I checked the oil level on the MMI today and it indicates that it's topped off.
    Will the MMI warn me if the engine oil is overfilled?
    If I put in ~8 quarts, should I siphon any out?
    I've sent in a sample for analysis, so I'll see what kind of condition the PO's oil was in, despite apparently being overfilled.
    Mar 28 2016
    Trust the dipstick. I would not trust the MMI.
    Veteran Member Four Rings if6ws9's Avatar
    Feb 08 2012
    Grand Cherokee
    Palm Harbor, Fl
    Yes, the MMI will warn you if there's too much oil but there's no way of knowing when you get that warning. You could check the MMI and not have the warning, then start out driving, then drive several miles, check the MMI and the warning will appear. But the warning is only visible when you re-check the oil level through the MMI, its not like a MIL or Low tire pressure warning. Trust the dipstick.
    2014 A5, Gloss Boat Blue, Black Optics, Sport package, MMI+, B&O, AWE Touring, AWE DP, USP HFC, CTS CAI, APR Stage 2, ST Coilovers, Alu Kruez, 034 TX insert, ECS diff bushing, Apikol blue diff mount, VAG's, Escort Redline, ZR4 shifters, 20% tint, Sprint Booster, ECS dipstick, FB steering wheel, piston diverter valve, ECS rear lower control arm brace, 10mm & 12mm spacers, BFI shift knob, CR 15, powder coated calipers, extended paddles, Vossen CV3-R's, Eurocode F&R sways, RS grille
    Nov 28 2017
    Carbondale, IL
    Quote Originally Posted by hilmar2k View Post
    It has a dipstick, and it looks mildly overfilled.
    From what I've read, 7.2 quarts is what it should take to be topped off--is 0.8 worth of overfilling worth draining out?
    - - - Updated - - -
    Quote Originally Posted by if6ws9 View Post
    So.. if I manually check the MMI a few times and it doesn't give any kind of warning for oil level, it's safe? I just checked it a short time ago this afternoon.
    Veteran Member Three Rings AFR1485's Avatar
    Nov 24 2015
    Fiat 500
    The MMi oil level indicates 1 quart. I add 7qts of oil and add based on MMi level.
    Nov 28 2017
    Carbondale, IL
    Quote Originally Posted by AFR1485 View Post
    Sorry, I don't follow.. what do you mean by "the MMI oil level indicates 1 quart". Like, the MMI gauge means you need to add 1 quart when it's all the way at the bottom?
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    For less than $ 30, grab a dipstick and forget the MMI.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Nov 24 2015
    Fiat 500
    Quote Originally Posted by thefleshrocket View Post
    Correct, if it’s at the bottoms then it needs 1 quart.
    My car tends to burn less than a quart between the 5k oil changes I perform. It’s completely normal for the engine to consume at that rate. I have found some oils are consumed less than others (probably another topic).
    Oct 14 2012
    Empty...for now...
    SE PA
    I don't think the MMI readout is as egregious as it is commonly hyperbolized to be here. I changed my oil a couple days ago and the dipstick was reading just above halfway when I was done, whereas the MMI was reading two tick marks below halfway. Not super precise, but enough to give me a quick idea of where I am. I've also noticed that the MMI tends to err on the low side which I would imagine is to build in margin for when the low oil alarm goes off vs. when the driver can reasonably stop to add more oil.
    All in all I 100% agree that the dipstick, as hard is it can be sometimes to read, is the best way to check the oil level, but in my experience the MMI readout is decent enough for a quick convenient reading.
    SOLD 2015 Daytona Gray S4
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    the MMI display (as long as the sensor is in good shape) is pretty comparable to the level on my dipstick if you follow the instructions in the owner manual on how to get a reading. I agree with SteveYem, it's not 100% accurate, however it's pretty close for what it is to where unless you really really really need to place your engine oil levels at a particular spot, the MMI is pretty decent.
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Established Member Two Rings ZGskibum's Avatar
    Jan 17 2016
    Aspen, CO
    I dunno if it’s just me, but I get radically variable dipstick readings and have come to completely mistrust it versus the MMI readout.
    First time I observed this was after draining oil from drain plug, pouring in 7 quarts, running car for a few minutes, and having dipstick read way, way past max. Scratched head for a while, re-drained and measured volume (sure enough, just under 7qts came out), re-filled, and same observation vis-a-vis the dipstick.
    So I started checking it at every fill up and various odd stops. It measures all over the place. Sometimes way over max, sometimes just right.
    At the end of the day, I decided Audi eschewed a dipstick in these cars because something about the oil system prevents accurate dipstick readings.
    2011 S4 6MT Sport Diff | Ibis w/ Black Optics
    APR Stg II+ | AMS Cooling | AWE Touring - Res DPs | Roc Euro Intake | Sachs X-Tend Clutch w/ USP SS Line & Lutz (OEM) FW | Stoptech ST-60 355 BBK w/ SS Lines | H&R OE Springs | Bilstein B8 Shocks/Struts | CR-15 | H&R Rear Sway | Alu Kreuz | 034 Trans/Engine/Diff./Strut Mounts | BC Forged EH 307 19x9 ET 40 (Summer - Michelin PS4) | VMR V810 19x9.5 ET 40 (Winter - Pirelli Sottozero) | ECS Shortshifter | P3
    Veteran Member Four Rings superswiss's Avatar
    Jan 07 2013
    San Francisco Bay Area, CA
    I never understood this obsession with the dipstick. The oil level has a 1 qt tolerance. The range between min/max is 1 qt. On an 8 qt fill, that's a 12.5% tolerance. The oil level doesn't need to be exact in other words. There are bigger fish to fry. As long as it is within 1 qt of full everything is fine. The MMI oil level is plenty accurate for a 12.5% tolerance. My indy shop doesn't even bother with a dipstick. They just fill and as it gets close to full they watch the MMI oil level go up in real time until full. I top off the same way. Turn on ignition, open the hood and start filling 0.5 qt look at the oil level then another 0.25 qt and so on, waiting a little bit in between for the level to catch up until the MMI shows full. Over about 4k my car burns about a qt anyway.
    To the OP, don't worry about it. As long as the MMI shows your oil level between Min and Max (again that's 1 qt) and there is no overfill warning or low oil warning you are good. If the sensor is faulty you get a warning, too. Mine crapped out sometime around 40k miles and it got replaced under warranty.
    2019 AMG C63CS, obsidian blk, blk leather w/ yellow stitching, aero pkg, CF pkg I+II, 19/20 wheels, lighting pkg, multimedia pkg, heat&vent seats, AMG perf seats, digital cluster, night pkg, parking assist, driver assist, european delivery
    2013 panther blk RS5, Ti pkg, blk leather/alcantara, nav pkg, sport exhaust, driver assist pkg, rear shade, alu kreuz, ECS spacers 15f/10r, ECS tru-float rotors, ECS brake lines, Hawk HPS pads, european delivery (sold)
    Mar 05 2015
    2009 A4 Cab: S-Line / 1996 Camaro Z28
    East Granby CT
    I would agree there is room for error here with the MMI - which is odd as the overwhelming ideal (for most cars) is oil needs to be watched like a hawk with little room for error.
    But the AUDI has indeed been able to work around that ideal - with that in mind I use the MMI to visually check once in a while - and confirm those findings with DipStick - as noted they are typically pretty close - so dipstick is great for quick check concerns and ease of use - MMI is in car visualization.....
    Best Answer is to use both and determine which one you find easier to follow to maintain good levels.
    2012 Moonlight Blue Metallic S4 | Premium + | DSG | 19" Peelers |Sports Diff | MMI w/Nav | B&O Audio | Advanced Key |
    After-Market Add-Ons: Rallitek Aluminum Paddles | USP LED Interior Lighting | Phillips Xtreme +50% Headlight Bulbs
    Performance Upgrades: 034 Stage 1 ECU & TCU | | APR I/C |
    Stoptech Cryo Slotted Rotors with Porterfield R4-S Pads |
    034 Springs / Koni Yellow shocks | Tires = Michelin Pilot 4S (255/35/19)
    Veteran Member Three Rings snocat17's Avatar
    May 12 2017
    2016 S5 Cab, 2016 Mazda CX-5, 2012 Ford F-250
    Steel City, USA
    If the MMI level is at "Min", add 1 qt oil. It it is about half, add 0.5 qt.
    -Joe
    2016 S5 Cabriolet Prestige Glacier White Metallic w/ brown comfort seats and piano wire black wood trim. RED Brake calipers holding EBC RedStuff pads, APR Carbonio Intake, ECS carbon fiber back-pipe, VCDS cable
    Veteran Member Three Rings Senseless's Avatar
    Aug 11 2015
    Phila vicinity/ PA/ US
    I've noticed with the dipstick, the car has to be very level. Even a slight backwards incline may read a half quart low when it's not, and vice versa.
    2012 S4
    Jan 07 2013
    Quote Originally Posted by Senseless View Post
    That's pretty normal. The oil level is only accurate if the car is level. The MMI may measure closer to the center and might be less affected by the car not being level, but in order to be sure you measure the correct level you need to follow the steps in the owner's manual and make sure the car is on level ground.
    Sent from mTalk
    Senior Member Three Rings DufraineMK6's Avatar
    Jan 09 2017
    2014 Monsoon S4 6MT
    Northern VA
    It’s pretty much as accurate as the tpms. Don’t be afraid to open your hood and get your hands dirty.
    14 S4 6MT - Sport Diff / H&R Street Performance Coilovers / CW Pro Stage 2 (6-1) 93/E85 Mix / JHM 179mm Crank Pulley (1300mm 7 Rib Belt) / ECS Tuning Flush Kit 10mm F & 12.5mm R / 034 Motorsports Intake Tube W/ AFE Pro Dry Filter / USP Stainless Steel Clutch Line / AWE Touring 102mm Stock Downpipes / Eurocode Trans Mount
