Results 1 to 11 of 11
    Veteran Member Four Rings rhfosu's Avatar
    Jan 01 2015
    Alexandria, VA
    Seat-Back glue recommendation?
    My front seat backs are coming off. I know this is a pretty standard Audi problem that can be fixed with adhesive. Anyone have a recommended glue they have used with good results?
    "I don't understand Audi enthusiasts. They buy a car that looks like a bar of soap, then they spend money modifying it so it looks slightly less like a bar of soap."
    Veteran Member Four Rings Willënskraft's Avatar
    Oct 14 2011
    2002 Audi A4 1.8TQ, 2007 Audi A4 2.0TQ
    Norcross, GA
    Quote Originally Posted by rhfosu View Post
    JB Weld epoxy, the key is to have a clean surface and some weight pressing on the back cover while it’s drying. I used a skateboard.
    "Beep beeeep bloop boop" - R2D2
    Aug 09 2012
    Sylvania OH
    I used the Gorilla epoxy on my passenger. Held it with a ratchet strap until it dried. The dealer’s body shop did my driver’s side about 7 years ago. No idea what they used.
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    PL premium adhesive, construction aerosol adhesive, or industrial epoxy.
    All should hold far better then oem glue.
    Veteran Member Three Rings Ray1031's Avatar
    Nov 01 2015
    San Antonio, TX
    Quote Originally Posted by Sylvania A4 View Post
    Same here
    Veteran Member Three Rings mgfranz's Avatar
    Apr 08 2016
    Mission Viejo, CA
    Any good RTV will work, there is really no "best" for this. All you need is a good flexible adhesive that you can let cure for 24 hours.
    When mine went I used a DAP Automotive/Marine RTV adhesive, been holding strong for almost 3 years now.
    2008 Audi B7
    2003 Ford F250 XLT
    2001 Porsche Boxster
    1999 BMW 740i M-Sport GONE
    Established Member Two Rings BillyK's Avatar
    Jul 22 2016
    Washington, DC
    JB weld fixed mine. Waited for cooler weather and used bungees to hold it until it cured.
    Jan 01 2015
    Alexandria, VA
    What did you guys use to clean off the old adhesive? Goo gone?
    Jan 13 2016
    Used JB Weld eboxy on mine, 2 years and counting since then and it hasn’t budged
    Veteran Member Four Rings tloft4's Avatar
    May 15 2016
    Lock Haven, PA
    Quote Originally Posted by BillyK View Post
    how long did that take? need to fix mine, last attempt was in super hot weather and didnt sit long enough at all. my car sits in my garage a lot and its probably under 75 at most
    Jul 22 2016
    Washington, DC
    I let it sit about 36 hours.
