hello guys,i'm a little stuck and can't sort out the abs.i get three beeps got a vcds and a full scan but can't find the cause of It. temporarily replaced the abs unit with the module with exact same number as mine to check if it will fix it but vcds could not communicate at all. so we swapped the abs unit again.i also have an aftermarket radio.
any help is greatly appreciated
here is the log of the vcds.
Chassis Type: 4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005)
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
Mileage: 264270km-164209miles
Address 01: Engine Labels: 059-907-401-AKE.clb
Part No: 3B0 907 401
Component: 2 2.5l/4VT EDC G200AG D50
Coding: 03001
Shop #: WSC 16078
VCID: 5ABA1FCCC6CB9D9409-4B00
1 Fault Found
18259 - Powertrain Data Bus
P1851 - 35-10 - Missing Message from ABS Controller - Intermittent
Readiness: N/A
Address 02: Auto Trans Labels: None
Part No: 4B0 927 156 B
Component: AG5 01V 2.5lTDI RdW 8915
Coding: 00000
Shop #: WSC 85555
VCID: 26427B3CC233E9747D-4B00
No fault code found.
Address 03: ABS Brakes Labels: 8E0-614-111-ASR.lbl
Part No: 8E0 614 111 H
Component: ABS/ASR 5.3 FRONT D10
Coding: 00011
Shop #: WSC 02325
VCID: 23446228B1011C5C1A-5100
3 Faults Found
18256 - Please check DTC Memory of Engine Controller
P1848 - 35-00 -
18263 - Powertrain Data Bus
P1855 - 35-00 - Software Version Monitoring
18258 - Powertrain Data Bus
P1850 - 35-00 - Missing Message from ECU
Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl
Part No: 4B0 820 043 G
Component: A6-Klimavollautomat D61
Coding: 00063
Shop #: WSC 16078
VCID: 1E3253DC9A6331B435-2580
1 Fault Found
01809 - Actuating Motor for Temperature Flap; Left (V158)
41-10 - Blocked or No Voltage - Intermittent
Address 15: Airbags Labels: 4B0-959-655-AI7.lbl
Part No: 4B0 959 655 J
Component: Airbag 7 Audi 0501
Coding: 00106
Shop #: WSC 02324
VCID: 377CA678159960FCD6-51C0
1 Fault Found
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 4B0-919-xxx-17.lbl
Part No: 4B0 919 880 G
Component: C5-KOMBIINSTR. VDO D08
Coding: 00160
Shop #: WSC 00000
VCID: 306E9D64F0F7B7C497-5180
Subsystem 1 - Part No: IMMO
Component: IDENTNR: AUZ7Z0W0539418
IMMO-IDENTNR: AUZ7Z0W0539418
1 Fault Found
01176 - Key
Address 35: Centr. Locks Labels:
VCID: 55A00CF0ACD5B2EC24-FFFE
