I got a P0068 code last night. After reading a bit, I figure it means either my manifold air pressure, or throttle position sensor is bad. I am going to try to clean my MAP as a first step.
I have a carista dongle. Is there any way to use that to monitor my throttle position and see if it is increasing and decreasing smoothly, or would I need to hook a multimeter up and check the voltages?
Has anyone else run into this? Just looking for some input from those more knowledgeable than myself.
