Results 1 to 12 of 12
    Mar 21 2018
    Raleigh
    SQ5 battery replacement
    My car is at the dealer getting it's 35,000 mile service and they said the battery is due for replacement soon. They scanned the car wth something and this is what it's telling them. Can I swap the battery myself, or does something need to be coded? I have Carista but no VCDS. Battery seems like it would be easy to swap since it;s in the trunk, I just wasnt sure about programming. Dealer quoted me $330 for a new battery. I figured I can do it myself for 1/2 of that. My SQ5 is a 2015 with 36,000 miles.
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Has it ever drained/died? That's soon... I only replaced my original battery last year, and I didn't even need too
    I highly recommend getting a VCDS or borrowing one. Or meeting with an Audiziner and play with their vag
    You can scan the battery health to make an informed decision. Battery ran me $170 and it was installed and programmed 10 minutes later. You need to pair the new one with the car.
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Feb 04 2017
    San Francisco/CA
    I needed mine around the same time and did it at the dealer due to the resets it needed.
    Mar 21 2018
    Raleigh
    I just had the dealer do it since it was already there. Thanks for the replies.
    Veteran Member Four Rings bajan01's Avatar
    Jan 11 2018
    2018 VW Atlas, 2016 VW Golf
    Florida
    Quote Originally Posted by billm0066 View Post
    What was the dealer cost of the battery alone (no labor)? I’m at 2.5 years (~43k miles) and living in Florida that’s a typical lifespan for a battery...My wife’s Sienna went through 3 batteries in the 8 years we had it.
    Veteran Member Three Rings Reggie's Avatar
    Feb 27 2005
    2014 SQ5 & 2015 RS5
    Fort Collins Coloardo
    My AGM batteries on my RS4 lasted 8 years. I have not needed to use a VAG-COM anytime I disconnected it
    Dec 04 2015
    Honda CRZ, Classic Mini
    San Francisco, California
    Do they no longer cover batteries under warranty? Not even a pro ration?
    Mar 21 2018
    Raleigh
    Quote Originally Posted by bajan01 View Post
    $330.
    Quote Originally Posted by Reggie View Post
    It's for replacement not disconnecting.
    Quote Originally Posted by WMeister View Post
    My car does not have a warranty, but since a battery is a wear item I doubt it. My car has a rebuilt title.
    Established Member Two Rings BierJager's Avatar
    Apr 28 2017
    2015 Highlander
    Michigan
    $330 and it can't take more than 30 minutes for them to swap it. I'm guessing the breakdown was about $200 for the battery and the rest was labor.
    That's just insane.
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    What did they charge for labor?
    Established Member Two Rings Rkost's Avatar
    May 28 2015
    Arizona
    I just had mine replaced at a Interstate store, the guys were dopes and had no idea where the battery was located, quoted me for the wrong battery but in the end honored the $165 price once it was finished. Anyways, I am positive they didn't code the battery to my system but I haven't had any trouble in over a year. I monitor the battery charge through my Carista and it's been reporting back perfectly fine.
    From what I understand the battery coding is supposed to tell the charging system how much to charge it, but if you match the OEM battery I don't know that it's needed IMO. I could be wrong but it's been fine for the past year.
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Feb 27 2005
    2014 SQ5 & 2015 RS5
    There is no difference in disconnecting the existing battery and replacing one. The car electronics reacts the same. As I said mine did not need to have a VAG-COM
