Results 1 to 6 of 6
    Jun 15 2010
    Chicago
    Has anyone replaced their power steering pump on their B8?
    Been hearing a loud gargling or whining sound for the past month or so. I thought it was the water pump since it's been 110K miles so I replace the thermostat and water pump. Turns out both parts were good and it might actually be the power steering pump going bad. Anyone have a DIY or tips on how to remove it? Also, do our radios need to be programmed? My XM quit working so I bought a used radio unit on eBay since I couldn't find a new OEM unit for a B8. I installed it and the XM appears again but the radio keeps cutting off every two seconds.
    2010 Audi S4 GIAC Stage 2 | 2007 Lexus IS350 Supercharged
    Senior Member Two Rings juniorcruzer's Avatar
    Sep 28 2014
    2007 Suburban
    Center City Minnesota
    I am looking for a power steering DIY also. Mine I know is bad, cause it turns like a military duece and a half.
    Jon
    2010 S4 3.0T, chipwerks stage I
    2010 A6 3.0T, APR Stage 2+, Roc Euro Intake, VMR V710 18x9.5 HyperSilver, 30% tint, A3 clear marker lights, LED Reverse lights, RS6 Grill
    Sep 05 2018
    Chillicothe, Ohio
    I am also (unfortunately) looking for a DIY. on how to remove / replace my 2011 S4 power steering pump. Ive flushed the system twice, bleed the system 3 times the pump is just noisy but my steering still works great...……. I hope I don't have to put the S4 into "service position" to get the pump out? Anyone done this job yet?
    Senior Member Two Rings Wreckm's Avatar
    Oct 30 2013
    San Gabriel California
    Did you guys have a power steering fluid leak or pumps just failed?
    Active Member Two Rings ken_bunker's Avatar
    Oct 22 2018
    fz09, b7a4, b8s4, 05 duramax, 92 toyota (built)
    Willamette Valley, Oregon
    Just to get to the power steering pump, youll have to have the front end stuff at least 10 inches forward to allow room to work. You'll need triple square/star bits if I remember right.
    2016 Yamaha FZ-09
    2005 B7A4 Avant 6MT tuned & 260k mile club
    2010 S4 DSG IE Dual Pulley + e40 soon.
    1992 Toyota Pickup 1UZ, SAS, 40s & all the trail goodies...
    Sep 05 2018
    Chillicothe, Ohio
    Quote Originally Posted by ken_bunker View Post
    Thanks a million for the heads up, I don't want to start working on the car only to find out I don't have the right tools.
    I just put the entire front end back together after changing belts, hoses, crankshaft pulley and tensioners now two weeks later I've gotta do it all over again for the power steering pump. Very Frustrating that its not a simple job.
    Does the steering pump need to come out from underneath the car (out and down) or does it need to be pulled out & Up? thanks again
