Results 1 to 26 of 26
Thread: Solar sunroof
    Mar 05 2013
    CA
    Solar sunroof
    It's hot outside.
    Anyone plan to retrofit this?
    OEM option.
    Quote Originally Posted by autobytel
    Audi's solar sunroof is a normal sunroof that has solar panels incorporated under the glass. The solar panels are used to provide power to the vehicle's climate control system fan, allowing it to blow fresh outside air into the car without draining the battery, even when the vehicle is turned off. The result is a temperature in the car that is up to 50% lower than without the system, enabling the air conditioning system to bring the interior temperature to desired levels more quickly and reducing energy consumption.
    Here's a B7 RS4 with it.
    Feb 17 2004
    Liberty Hill, TX
    it was on my to-do list for the B6 and never got around to it, but may have to revisit now with the RS, especially if there's a retrofit harness (eg, Kufatec) available
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Mar 05 2013
    CA
    Quote Originally Posted by Matt Devo View Post
    I'm not sure what's required of it,
    but did see one (B6/8E) listed for sale in Germany some time ago.
    IDK if any other model ones fit. For example, D3 A8L sunroof looks roughly similar, but IDK if it's exactly the same parts.
    It probably exists on the C5 A6 platform too.
    There's various window things out there. Such as tint, roll-up shades, and shade insert pieces,
    but that doesn't cover actually operating the A/C.
    No idea if heat actually transmits through the metal parts of the car (vs. glass windows), such as roof, doors, etc. and if any liner products exist to reduce that.
    Mar 21 2016
    69 Nova
    California
    Our compressors aren't electric, though, so would we have to retrofit a new compressor as well?
    Seems interesting.
    12 S4 Quattro 6 Speed
    04 A4 3.0 Quattro 6 Speed
    69 Nova with a bunch of stuffs
    19 Sportster 883
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    Quote Originally Posted by DarkoNova View Post
    Seems interesting.
    It only spins the fan to pull fresh air into the cabin, the panel is way too small to power an AC pump.
    Veteran Member Three Rings Osher67's Avatar
    Nov 03 2012
    California/so cal
    Quote Originally Posted by Kevin C View Post
    I wonder how effective it is at keeping hot cars little cooler in the sun.
    -Josh
    2002 01A Quattro
    K04-15 (Unitronic)
    Nov 03 2011
    All Over!
    I had this in my D2 S8. Very effective, though it only blew really cold air shortly after shutting down the engine.
    Once the compressor wasn’t engaged, the air gradually rose in temperature, though still cooler than without the solar system.
    It was also very effective in heating up, or keeping the interior warm in winter, if the coolant was at temperature, and a hot setting was selected on the control panel.
    1986 Type 85 Audi 90 quattro
    Mar 21 2016
    69 Nova
    California
    Ah, guess I read it wrong.
    Still pretty cool!
    Can you still open the sunroof like normal or does it become stationary?
    19 Sportster 883
    Nov 03 2011
    All Over!
    The solar sunroof opens as per regular steel or glass panel.
    Mar 21 2016
    69 Nova
    California
    Oh man that's awesome.
    19 Sportster 883
    Jan 24 2010
    Paramus,NJ USA
    This was an option you could get.I guess it would make a big difference if you live in AZ or something.Worth the money I dont think so.
    Ziddy Autowerks
    Jan 18 2016
    '14 A6 TDI, 01 TT 225Q Roadster Nimbus/Amber Baseball
    NH
    I thought it retracted, but you lost the tilt functionality. Of course I could be remembering wrong - only read posts, have never owned/seen on in use personally.
    Mar 21 2016
    69 Nova
    California
    Quote Originally Posted by EuroxS4 View Post
    I dunno, spike posted a link to a few on eBay. The most expensive one was like $150.
    Depending on what else is required, that's not bad.
    But then, the hassle of swapping the entire glass piece out, that's the part that I think will determine whether or not it's worth it.
    19 Sportster 883
    Feb 17 2004
    Liberty Hill, TX
    it's like 3 screws on each side, a 5 min job at most. If you have to do the whole track, then obv much more involved since the headliner has to come out
    Senior Member Three Rings DetRebel's Avatar
    Mar 20 2017
    Chevy Trailblazer (the real daily driver); previous car: '11 Brilliant Black B8 A4
    Detroit
    Wow that’s cool!
    Mar 27 2018
    Rosamond
    This is genius. As someone living in Cali, I'm surprised I've never heard of this before
    Sent from my ONE A2005 using Audizine mobile app
    Mar 05 2013
    CA
    Honestly I've only ever had dark cars and am curious to know how much better a light one is, anywhere in the country.
    In which case, maybe it's cool enough to not think of this. Such as light on light paint scheme.
    Maybe silver paint and light grey interior, though that may not look as good. Light grey interior or just good window tint.
    or a white car.
    I pulled my stock sunroof glass out before once, and it seemed to weigh like 30lbs, vs. doing a sunroof delete (less weight)
    BUT, it might've been with the headliner pieces already down and removed, to re-upholster them. "While I was in there".
    So it's not exactly the easiest thing or possible to just reach up and remove it, I think. Though I'm not sure.
    Mar 21 2016
    69 Nova
    California
    Yeah that's what I meant. I've swapped from a metal sunroof to a glass one on my e30 and it was cake.
    But I've also had to replace tracks on an e31 and it was hell.
    If you can just swap the glass and do some wiring, then that's awesome and totally worth it, IMO.
    19 Sportster 883
    Veteran Member Four Rings jubei4769's Avatar
    Feb 09 2012
    79 VW Rabbit / 09 Triumph Daytona 675
    Kailua, HI
    Had one on my C5 S6, was more of a pain than anything and didn’t keep the car that much cooler. Plus you couldn’t use it as a moonroof and let light thru.
    instagram: @low_n_slo
    https://forums.vwvortex.com/showthre...le/page2&amp=1
    79 VW Rabbit 🐇
    13 VW Golf R 🚗
    09 Triumph Daytona 675 🏍
    Feb 09 2012
    Kailua, HI
    Quote Originally Posted by quattrosnrabbit View Post
    Mine still tilted, retracted. Even though it’s hard to see
    79 VW Rabbit 🐇
    13 VW Golf R 🚗
    Mar 05 2013
    CA
    There's also a way to refrigerate the glovebox.
    https://www.ecstuning.com/News/Audi_...007_2008_2009/
    Jan 24 2010
    Paramus,NJ USA
    Quote Originally Posted by Spike00513 View Post
    You need the special glovebox otherwise it will start growing mold.
    Ziddy Autowerks
    Veteran Member Four Rings fR3ZNO's Avatar
    Feb 09 2013
    WNY
    Yes, there's a specific insert for the glovebox that's meant to be used with the pipe from the evaporator, even though ECS says you don't.
    Although, the air would be fairly dry already and not conducive to condensation issues anyway.
    8E1-862-807-A
    "If one does not fail at times, then one has not challenged himself." - Ferdinand Porsche
    Mar 21 2016
    69 Nova
    California
    Yeah, I don't really see why you'd need a special insert for the glovebox since the air is already cool and dry...
    Kind of a weird idea, anyway. It's cool, but why would you need the glovebox cooled?
    19 Sportster 883
    Nov 03 2011
    All Over!
    Sudden changes in temperature can cause condensation. This will promote the growth of mold.
    Why would one need the glove compartment cooled? Well, to keep cans / bottles of drink cold, or even store candy bars, where they would melt in hot weather.
