Results 1 to 11 of 11
    Nov 17 2009
    C5 A6 rear seat cup holders in vanilla
    C5 A6 rear seat cup holders in vanilla. Function great. Should fit all c5 a6, s6, rs6.
    Cup holders are $25 shipped each in the US. Both for $45 shipped.
    Face plate $10 shipped or $5 if you also get a cup holder.
    Thanks.
    996 TT
    MKIV Supra TT
    LX570
    Senior Member Three Rings Grainreaper's Avatar
    Nov 19 2016
    Lake in the Hills, Illinois
    Both cup holders work well? Both of mine are inop, and I’ve been trying to figure out how to remove them, all the how to guides have dead pic links and little in the way of description
    - - - Updated - - -
    Vanilla is a tough color to find too
    Nov 17 2009
    Yes, they function perfectly.
    Removal is a bit tricky. First you pry on the trim panel that goes around both to get access to the tabs. Then if you look at my pic where it shows both from on top you can see there is an indentation at the front left and right of the cup holder. There are tabs in the cage that hold them in at those two locations. You have to use two small screwdrivers to push the tabs up and slowly pull the cup holder out. A very bright flash light help to see the tiny plastic tab.
    996 TT
    MKIV Supra TT
    LX570
    Nov 19 2016
    The very outer edges at the front? Rectangular bits? Just jam a pocket screwdriver into each location at the top between cage and cupholder? Sounds easy enough.
    Nov 17 2009
    Yup, its just a matter of finding the right place to push up as its not apparent and quite tight in there with the cup holders still in the housing. First one took a while but second one only took a few seconds once I knew where to push up.
    996 TT
    MKIV Supra TT
    LX570
    Nov 19 2016
    I’m interested... I’ll check funds when I get back from vacation and hit you up! Thanks for the info!
    Veteran Member Four Rings m_haiser's Avatar
    Apr 24 2011
    2012 A6 Prestige, 1998 Jeep Cherokee XJ
    Central Willamette Valley
    thank you Ali! one of my rear cup holders wouldn't pop out and now its fixed since I was able to remove it and fix it!
    Nov 17 2009
    Quote Originally Posted by Grainreaper View Post
    Sounds good, enjoy your vacation.
    Quote Originally Posted by m_haiser View Post
    Glad to help. When I was trying to remove them I really could not find any clear instructions either.
    996 TT
    MKIV Supra TT
    LX570
    Nov 19 2016
    When photobucket went pay to play, lots of useful threads on many forums went to crap.
    Apr 24 2011
    there is a plugin for google chrome as well
