Results 1 to 23 of 23
    Jul 01 2018
    Ohio
    Audi A3 8V Lowering Springs
    I have a Audi A3 8V and I just got vmr v710s 19x8.5 et35 wheels with 235/35 tires. I’ve been looking at Emmanuel Design lowering springs for the car. Does anybody have a similar set up? Wanting to know how they ride and I don’t want to rub even when having 5 people in the car.
    Veteran Member Four Rings ralphie_43's Avatar
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Quote Originally Posted by Johnhays17 View Post
    I have 18×9 et 30 with 245/40/18 tires on neuspeed springs I rub on occasion when I hit a bump on the highway, and always rub over bumps when I have people sitting in the rear I would suggest getting coils unless the springs have a stiff rate
    Sent from my SM-G930V using Audizine mobile app
    Veteran Member Three Rings bl0wn3ur0's Avatar
    Jul 22 2008
    NY/PA
    any pics of the car on those springs??? Just leased a 2018 A3 and i'm looking into lowering springs
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Quote Originally Posted by bl0wn3ur0 View Post
    Yup here are some of my carIMG_20180701_120710_794.jpeg20180624_102844.jpeg20180330_161630.jpeg20180211_174047.jpeg
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Ralphie, are those Alzor wheels from ECS tuning? Looks Staggered? Was thinking about those. I'd run 255/35 which is almost 1/2" shorter and I'm on 034 springs which are a bit higher, so thinking no rub with that setup.... (also running camber plates in front, so quite a bit of extra clearance)
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Quote Originally Posted by Spinnetti View Post
    Yes they're alzor 020's they're 18x9 et30 squared on a 245/40 I do rub on the rear gonna get a new alignment to see if I can add some more camber to the rear or just roll the rear fenders
    Jul 22 2008
    NY/PA
    Quote Originally Posted by ralphie_43 View Post
    car looks great, are you on sport shocks or the regular a3 suspension?
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Its on normal a3 suspension
    Established Member Two Rings luv4dubs's Avatar
    Apr 23 2018
    Parlin, NJ
    My car is an Audi A3 8V with VMR 710's - 19x8.5 ET 35 and Conti 235/35 tires and I have the Emmanuel Design Stage 1 Lowering Kit. (Rear Sway Bar added) Here you go:
    Veteran Member Three Rings Chaoscreature's Avatar
    May 26 2018
    2018 A3 Quattro, 1995 Porsche 993 C2, 2006 Jetta TDI Special Edition, 1956 Willy CJ5
    Vista, CA
    Ralhpie,
    Nice pictures! I especially like the last one with the sunset (or sunrise?). Very nice!
    What tires are you running? Some run much wider or square than others.
    Anyone here running OEM Sport shocks with aftermarket springs? I have some H&R Sport springs in my garage, but haven't installed them yet. I am sure they will work for a while, but if someone here has that package I would be interested in hearing about it.
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Quote Originally Posted by Chaoscreature View Post
    Ralhpie,
    Thanks! Yea it was a sunset. I'm running michelin pilot sport a/s 3+ 245/40R18. The non sport shock WERE amazing at stock height with stock springs the ride is a little harder with aftermarket springs looking into some coils now which is honestly a better mod to do if you have the cash at hand or to pair bilstein b8 shocks with springs I know a few people running that and their cars feel great
    May 26 2018
    Vista, CA
    A Bilstein PSS setup is my long term plan, but funding is tight right now.
    I do the work myself so I won’t lose out too much on the H&R Springs when I make the swap.
    I ran H&R sports with Koni Sports on my MK6 Jetta, which is not terribly different than the A3 platform, and it was a great combination as well.
    Aug 10 2016
    Ohio
    Jan 12 2015
    Columbus/OH
    Quote Originally Posted by Somejace View Post
    Wheel & tire specs?
    Jan 03 2019
    Va
    18x8 45 on 225’s. H&R Super Sports
    Senior Member Three Rings CronicPAIN's Avatar
    Jun 16 2016
    Honda%20CRV
    pennsylvania
    Sent from my SM-G950U1 using Audizine mobile app
    May 26 2018
    Vista, CA
    Charvey,
    I always recommend lowering springs to cheap coilovers. Adjustability is over-rated, most people set the height once and never mess with their suspension again.
    Get your tires, enjoy the car, and if you really want to upgrade to coilovers you can swap them out later.
    Established Member Two Rings charvey's Avatar
    Dec 13 2018
    Ohio
    Thanks for the reply man
    I think I'm gonna go with some hr sports then. Do you have any experience with them and if they are not good what do you recommend? Would an upgraded rear swaybar be beneficial with the lowering springs also?
    Veteran Member Three Rings S3_Miles's Avatar
    Jun 13 2018
    Paso Robles CA
    Quote Originally Posted by charvey View Post
    I can tell you the H&Rs seem to get mixed reviews on here. I had a set on my B8 2011 A5 and the ride was a bit harsh with the stock dampers. I am looking at the Emmanuel Designs springs and rear sway bar next month for my wife's 2016 A3 Quattro as many on here seem to compliment them and from what i've read you can run your stock shocks ok with them.
    I highly recommend the sway bar. I installed a Neuspeed rear sway bar on my 2015 S3 and run it on the stiffest setting. Also bought their billet endlinks. It transformed the car in a way I could feel on turn-in. The 034Motorsports swaybar has a premium feature of having greasing nipples installed for the occasion need to grease. I havent needed to grease my mounts since installing the Neuspeed but im sure the day will come.
    Im pretty much going to have the exact set up luv4dubs has above, with the EMD springs and rear sway bar, but with a cheap set of VMR 710 knock offs in the same size and offset (Alzor 040's). They are going on my wife's car and she tends to curb wheels sooooo didnt want to spend anymore than I had to on wheels lol
    Dec 13 2018
    Ohio
    Alright I'm gonna look into the emmanueles then because I daily drive the A3 and I don't want it to be to harsh a ride. I cant wait to do springs and a roll bar I think it will really stiffen up the handling.
    Apr 23 2018
    Parlin, NJ
    I have them for sale and I've only put 1,000 miles on them. Honestly. We could even meet in Pa somewhere to cut down on shipping.
    Click here:
    https://www.audizine.com/forum/showt...uspension-Sale
    Dec 13 2018
    Ohio
    Quote Originally Posted by luv4dubs View Post
    Click here:
    I might take you up on one of those offers. I'll pm you when I get home.
    Dec 13 2018
    Ohio
    I sent you a pm
