Results 41 to 80 of 92
  1. #41
    Dec 05 2010
    Los Angeles, CA
    Quote Originally Posted by RSKYBET View Post
    Racing Line makes some pretty nice aluminum full replacements.
    https://www.racingline.com/vwr49g700
    Do you know the price? I don’t see it on their website.
    2019 Nardo with all OEM options
  2. #42
    Veteran Member Three Rings thebc's Avatar
    Jun 02 2013
    Boston, MA
    Quote Originally Posted by xliv View Post
    Who did you go to for the MMI carbon fiber facelift?
    The center console is from Neidfaktor.
    '18 RS 3 - Gretchen build thread
    '16 Golf R /sold
    '10 S4 /sold
  3. #43
    Dec 05 2010
    Los Angeles, CA
    Quote Originally Posted by thebc View Post
    I am running the TAW Chicago full replacements on a wheel I bought from them. I had red extenders I got from Winn but at the end of the day my ocd wouldn’t have it so went with the full replacements.
    Does the paddle shifter installation (full replacement, not extenders) require taking off the wheel? For VW all you need to do is remove a pin with a needle nose pliers and remove the OEM paddles. The new ones fit in the same space and you place the pin back in - 10 min job.
  4. #44
    Aug 17 2019
    Sunshine State
    Quote Originally Posted by BzzzBom View Post
    Price in the UK for them is £192 which works out to about $240
  5. #45
    Dec 21 2019
    In case anyone wanted to see what the satin silver Leyo extensions look like. Really dig the raised ridge in the back - adds a nice tactile dimension.
  6. #46
    Jan 11 2020
    2016 S3, 2015 Q7 TDI
    Bay Area
    P5stunna- Quick question... How close is the red set to the RS Design Selection air vent trims' red tone IRL? I am waffling on black vs. red, since I haven't seeing them installed in-person (vs pictures) of how close the black or the red match the trim elements. The silver, at least from pictures, does not appear to be polished enough to be a close match to the silver trim on the rs3 paddles, while the black looks pretty close (at least in sheen) to the piano black gloss of the OEM paddle it would be sitting against. Given you have the red, did/if you held them next to the vent rings, how close is the color? If the shade is a bit different IRL, I guess I would get black for my cabin OCD. Thanks
  7. #47
    Veteran Member Three Rings XMetal's Avatar
    Nov 02 2017
    CA
    The silver looks great! I love it so much more than stock! Here's mine in black - a bit more stealth.
    Quote Originally Posted by Kase Zome View Post
    2018 Audi S3 Premium Plus
    Navarra Blue Metallic/Magma Red - Technology, Dynamic, S Sport, Black Optic, Resonator Delete, Unitronic Turbo Inlet, EQT Stage1 ECU/TCU
  8. #48
    Senior Member Three Rings Phayl's Avatar
    Dec 12 2017
    Dallas, TX
    Quote Originally Posted by XMetal View Post
    Black looks a lot better with A3/S3 black paddles imo.
    Silver accents the larger silver OE RS paddles. Definitely would go silver.
  9. #49
    Jan 11 2020
    Bay Area
    Just saw a video of a guy with the Leyo paddles in an RS5 and they were hitting the lights/turnsignal stalk when the wheel was turned and the stalk was pulled towards the driver (like activating brights). Is this replicable/an issue in the RS3? Thanks in advance.
  10. #50
    Jun 07 2019
    2017 S6
    NC
    I'm selling a set of red Leyo paddle shifters if anyone is interested. PM me.
  11. #51
    Registered Member One Ring Walternate's Avatar
    Aug 08 2018
    non EU part of Europe
    No, you will just need to remove the airbag as the paddles are secured in place by a single screw from the inside
  12. #52
    Veteran Member Four Rings xander3zero's Avatar
    May 30 2013
    Rhode Island
    Quote Originally Posted by Walternate View Post
    Is there a good DIY for removing the airbag?
    From your post I assume it can be done with the wheel still mounted to the column?
    I'd like some nicer paddles on my S3 and debating full replacements vs. Leyo extensions.. the deciding factor being how difficult/PITA it would be to install replacements haha.
    Sent from my Pixel 2 using Audizine Forum mobile app
    2017 Audi S3
    Mythos Black Metallic | Dynamic Package | Tech Package | S Sport Seats | Bang & Olufsen
    Previous:
    2013 Allroad Premium+
    2006 A4 Quattro 6MT
  13. #53
    Nov 02 2017
    CA
    Here you go => https://www.youtube.com/watch?v=L7BrjzYMp_k
    Personally, I wouldn't want to mess with it. It's easily reversible with those Leyo extensions if you decides against it later on.
    Quote Originally Posted by xander3zero View Post
  14. #54
    May 30 2013
    Rhode Island
    There was a post up a ways about Leyo extensions interfering with the cruise/headlight stalk when they were pulled forward... Has anyone seen that or is that a non-issue?
    2017 Audi S3
    Previous:
    2006 A4 Quattro 6MT
  15. #55
    Nov 02 2017
    CA
    See post #47 - I don't have any issues with mine as do many others on this thread. There are plenty of clearance for the stalks. That post about Leyo extensions interfering with the cruise/headlight stalk when they were pulled forward was referencing an RS5, How was that relevant to the S3/RS3?
  16. #56
    May 30 2013
    Rhode Island
    Hmm was just following up to see if that was the case for anyone... If it was relevant on one of their products there's a good chance it carried over to this platform as well, but thanks for your input.
    2017 Audi S3
    Previous:
    2006 A4 Quattro 6MT
  17. #57
    Veteran Member Three Rings carlosvjr92's Avatar
    Nov 25 2015
    Miami, FL
    I haven't personally done it, but saw a DIY somewhere and it looks pretty striaght forward. I personally would not mess with the air bag. It sucks because I think with the paddles in the RS3 the stick on options just don't look great. Its usually very obvious that they are stick on and not full replacements which makes them look a bit cheap IMO.
    2018 RS3 (Cumulus Blue) - APR Stage 2 || APR Intake || APR Downpipe
  18. #58
    May 30 2013
    Rhode Island
    Quote Originally Posted by carlosvjr92 View Post
    Yeah I just watched the DIY. It does look pretty straight forward but I also have some hesitation towards messing with an airbag.
    Also, anyone who has done any trim removal on an Audi knows how much of a PITA it can be to remove trim clips and how easily they can be damaged. Every DIY I've watched always makes trim removal look 10x easier than it actually is lol.
    I think given that the S3 has pretty small factory paddles, the extensions might blend in pretty well, so I might go that route.
    2017 Audi S3
    Previous:
    2006 A4 Quattro 6MT
  19. #59
    May 30 2013
    Rhode Island
    Does anyone have experience with the Axmotiv extensions?
    Looks like those and the Leyo design both use a clamp on style... Wondering how they compare.
    2017 Audi S3
    Previous:
    2006 A4 Quattro 6MT
  20. #60
    Nov 18 2017
    Melbourne/Victoria/Australia
    I use the axmotive one. I chose them mainly because of the clap style. I didn’t was to stick anything to my car. The paddles look nice and work well of the most part. The very top 1cm isn’t stiff enough to allow gear shifting though. But that’s and issue wit all paddles. I believe it’s a limitation of the Audi shifting mechanism itself and not the extensions.
  21. #61
    May 30 2013
    Rhode Island
    Quote Originally Posted by cavebob View Post
    Thanks for the info... That's what I was reading about the extensions not functioning at the very ends..
    Honestly that's kinda dumb, why can't a company just make a revision that's shorter and works along the whole length. I think most people agree the extensions seem overly long - I'd just like another 1.5-2" of extension from my factory paddle, not 3-4" lol.
    2017 Audi S3
    Previous:
    2006 A4 Quattro 6MT
  22. #62
    Nov 02 2017
    CA
    2 reasons why I chose Leyo over the Axmotive:
    1. I wanted more lateral extension toward the wheel so I don't have to reach for it as much, which the Leyo provided, but not Axmotive nor do many others.
    2. Axmotive looks a bit more "Rice", but this is a personal opinion.
  23. #63
    May 30 2013
    Rhode Island
    Thanks for that info.
    I actually dislike that the Leyo ones have the text written on them and thing the Axmotiv blend a little better, but like you said - personal preference.
    2017 Audi S3
    Previous:
    2006 A4 Quattro 6MT
  24. #64
    Nov 02 2017
    CA
    Yeah - I'm not too crazy with text either, but Leyo was the only one that I could find that also extends it wider, which made it an easier reach for me while everything else mainly extends longer, which isn't that useful to me. I don't have super long fingers, so making a shorter reach was more important to me.
  25. #65
    May 30 2013
    Rhode Island
    Seems like someone should come out and make a nicer design lol, wonder if Leyo/Axmotiv have their mounting designs patented lol.
    2017 Audi S3
    Previous:
    2006 A4 Quattro 6MT
  26. #66
    May 08 2020
    2015 Golf R DSG, 2015 Golf TDI 6-speed.
    Purcellville VA
    We've had very good service from this vendor on our various model vehicles, including our 2019 Audi RS 3 as shown below, as well as our other vehicles such as our 2015 Golf R and a number of other vehicles over the years.
    This product is from https://www.dsg-paddles.com/collecti...addle-shifters. They make many different paddle styles for a great many different vehicles.
    Rod RS-3
  27. #67
    May 30 2013
    Rhode Island
    Quote Originally Posted by Rod Paine View Post
    Those are adhesive backed paddles, correct?
    2017 Audi S3
    Previous:
    2006 A4 Quattro 6MT
  28. #68
    May 08 2020
    Purcellville VA
    Yes as the link to the paddles web page says. Very secure indeed as I've had considerable experience with the 3M product used.
    Rod RS-3
  29. #69
    Mar 06 2020
    TX
    Paddle Shifter Extensions?
    I agree. I dont understand why there isn’t a company that makes a billet metal paddle that is just a little bigger than the factory paddle, fits in the stock location, but feels better. Something like a porsche pdk style /sized paddle. I would imagine there would be a market with how many people complain about the 2010-2020 paddles. I know im in the minority but the stock ones dont bother me THAT much but metal would be nice.
  30. #70
    May 30 2013
    Rhode Island
    Quote Originally Posted by AudiRS# View Post
    Yeah I totally agree.
    Doesn't even seem to be many aluminum replacement paddles, mostly CF from what I can see. I think CF wouldn't sit right inside a S3 cockpit unless you had some other carbon in there.
    2017 Audi S3
    Previous:
    2006 A4 Quattro 6MT
  31. #71
    Mar 28 2018
    So these guys have urus like paddles that are direct replacement for our car with no modifications needed . I haven't purchased a set yet but will soon Screenshot_20201212-205034_Messenger.jpg
    Sent from my SM-G950U using Audizine mobile app
  32. #72
    Junior Member Two Rings
    Jan 22 2020
    Winnipeg
    Quote Originally Posted by UNFUXWITHABLE View Post
    I recently bought them, just have to wait until next spring to install because I don’t want to break anything during the install due to the cold.
    I had been in touch with Dion prior to ordering them, and he always responded right away. I would wholeheartedly recommend buying from him!
  33. #73
    Veteran Member Three Rings UberDave's Avatar
    Mar 15 2008
    TX
    Here’s a good video of what it takes to install the DS Urus paddles.
    https://youtu.be/FLt2Ed-707U
    Current:
    2018 RS3 Florett Silver
    Previous:
    2005 S4, 99.5 A4 2.8 w/PES G2
  34. #74
    Nov 25 2015
    Miami, FL
    Just got the leyo extensions to try them out and I’m not a huge fan. They feel harder to use than the stock paddles because it requires reaching further with your fingers to operate the paddles. They do look pretty good for not being full replacements though. Going to test them for a few days and see if I keep them or not
  35. #75
    Nov 02 2017
    CA
    What do you mean you have to reach further to operate them? They extend the paddles more towards the circumference of the wheel, which means less reach. I like them a lot because they made the paddles easier to reach, IMHO.
  36. #76
    Nov 25 2015
    Miami, FL
    I mean they are further back from the wheel slightly. Its not terrible, but if you have shorter fingers they are a bit more awkward to operate than the OEM paddles on their own so in the end it doesn't feel any better than OEM paddles. May just take some getting used to since they are pretty large extensions. I had some stick on ones on my SQ5 that were the perfect size, but hate the idea of sticking something on to the paddles like that just sounds wrong (even though they feel perfectly fine and I never had any issues).
  37. #77
    May 27 2019
    Orlando/fl/south east
    My 2012 big turbo Mitsubishi Ralliart that I paid 13k for came stock with better paddles than my 52k Rs3. The Mitsubishi is aluminum and long. Also attached to the column rather than the wheel. I like that better too. Not complaining too much, just a funny observation.
  38. #78
    Jul 26 2020
    Chicago, IL
    Impulse purchased this DSG Paddles one on Black Friday but liking the racing lineone https://www.dsg-paddles.com/collecti...12611263463523
    2021 TT RS Daytona Gray
    Instagram @car.done_ttrs
    Recent past:
    2020 RS 3 Mythos Black
    2019 RS 5 Sportback Nardo Gray
  39. #79
    Nov 25 2015
    Miami, FL
    Quote Originally Posted by car.done View Post
    Those look pretty nice. I am guessing they go on with adhesive?
  40. #80
    May 30 2013
    Rhode Island
    I think all the options from DSG paddles go on with adhesive.
    For some reason it seems tacky (no pun intended haha) but I am wondering if they feel mushy or rigidly attached with that method.
    2017 Audi S3
    Previous:
    2006 A4 Quattro 6MT
