Originally Posted by
NickLim
Hello,
I bought my car earlier this year and now I am ready to do a major tune up.
I want to do an ECU tune, stage 1, 2, etc
I also want to do PVC replacement (burning 1qt a week)
Thermostat?
Maybe I will do a roc euro intake at the same time.
What should I do basically to get this car into tip top shape? What stage tune, etc I just want to go into a shop and negotiate a good price on everything.
Please give your recommendations for tunes etc - I have APR and GIAC tuners within 30 minutes of me
I don't think I have a tune because I can't go over 125mph, but I can use the break and the gas at the same time. I also emailed APr and they said that I didn't have the tune. I think if I do all of the work at once it may be the best thing for price and time.
Should I maybe do seals at the same time?
Thank you!
Hopefully other members with 3.0t c6 can use this thread as it will contain all the major tune ups
I can't offer any insight into tunes.
If you do not know the car's previous maintenance history, go ahead and do it all so you have a clean slate!
Spark plugs, air filter, oil and oil filter. Depending on the mileage look at doing the drivetrain fluids as well. Being that it's a 3.0T, definitely go ahead and replace the thermostat. Also, give the harmonic balancer a good visual inspection checking for cracks in the rubber. This would be an indicator of pending separation and that's a headache you'd want to avoid.
As for seals/ gaskets, if it ain't broke don't fix it lol. You can do a visual inspection around your engine bay before going to the shop and tell them what seals/ gaskets you want replaced (alternatively, have them find leaks if any, and show them to you before you approve the replacement). Unless of course you just want the peace of mind of knowing they've been replaced and you don't have to worry about them leaking for years to come.
The PCV system is actually a big project as it involves lifting the intake manifold AND supercharger. If you do this, you REALLY should replace the oil filter housing gasket (since you'd have to remove the IM and SC again to get to this). The PCV is not a valve per say as in other cars. We have an oil separator system. You have a medusa of plastic lines (two that go to the valve covers, and one that goes to the back of the IM behind the TB), and the oil separator box that sits in the valley under the IM + SC + fuel lines. Also, while the IM is off, you can have them inspect the back of the intake valves to see if it would be worth having them cleaned out. Given that you mention having to top off a qt a week, they may be gummed up with carbon so expect that bill.
Hope that helps!
