Replaced this today. Waited until I got a good deal on a used sensor on ebay. Mk7 GTI uses the same sensor, albeit a newer design. The new design fits and works in the S4. Two notes - firstly I assumed for some reason that the sensor was mounted horizontally, but it's mounted seemingly horizontally, with the sensor facing inward toward the motor, with the connector coming off toward the driver side. Secondly, it was hard to tell if/when I had all 4 of the clips secured in place. I'm still not sure they're all clipped. Downside is the hose it mounts into seems to be plastic, and I think I may have cracked it when I was pushing in on the sensor. We will see if I end up with a SAI pressure too low/leak code. For now the MIL is off.
