Results 1 to 34 of 34
    Senior Member Three Rings altobeast's Avatar
    Apr 09 2018
    WA
    X-Pipe or Downpipe first?
    Title says it all, what are your experiences with just an X-pipe or just a non-res downpipe? For example, AWE's non-res downpipe vs ECS x-pipe in terms of volume gain and drone control.
    Veteran Member Three Rings Delasangre4231's Avatar
    Nov 22 2012
    Portland, Oregon
    I have the ECS X-pipe on the way for my RS5 so I will let you know what I think, but the only RS5 I have heard in person is mine lol
    -2016 VW GTI Autobahn Performance pack DSG
    Michelin Pilot Super Sports, APR Carbon Fiber Intake, APR Stage 1 ECU tune
    -2003 VW Golf 2.0 5-speed SOLD
    -2013 Audi RS5 Phantom Black Pearl SOLD
    Michelin Pilot Sport 4S, ECS Brake lines with Motul RBF600, ECS X-Pipe, Leyo Motorsports paddle extensions
    -2003 Audi A4 Avant, 6MT, 3.0 V6 SOLD
    B6 S4 front brakes, JHM stainless brake lines, Straight Pipe - http://youtu.be/7zsiB7rT1fo
    Aug 28 2015
    Illinois
    Love the ECS X-pipe on my RS5...its a Dr. Jekyll and Mr. Hyde thing
    Prism Silver RS5
    Apr 09 2018
    WA
    Quote Originally Posted by Delasangre4231 View Post
    That's what I was thinking to do first, most budget friendly but it requires a cut, whereas the downpipe is bolt-on.
    Pedro, did you cut yours by yourself and do you have any regrets to where you would want to go back to stock?
    Nov 22 2012
    Portland, Oregon
    Quote Originally Posted by altobeast View Post
    When I watch this video Audi RS5 Resonator Delete vs Centre Muffler Delete it seems to me the downpipes get more high strung and the center x-pipe keeps deeper tone to it. I know no youtube video will do it justice. My plan is to do the X-pipe for the volume for now and I am going to do a full downpipe back exhaust next summer once I save up for it.
    I also ordered a Scwaben exhaust cutter with the X-pipe to do it myself on ramps in my driveway. Scwaben Exhaust Cutter
    This is a topic for a whole other discussion but after looking at ALL the exhaust options for the car including JHM and VelocityAP I have decided on Kline Innovations from Romania. They already told me the price and options and how much shipping to the US will be so its just a matter of saving up. 2013 Audi RS5 WOT Acceleration - Kline
    Apr 09 2018
    WA
    Yeah I'm between Kline and GTHaus at this point for next year
    Sep 29 2007
    Oakland
    Also have a ECS X pipe, you can’t beat it for the price. Deeper tone than stock, but I will say that it does leave you thirsting for more sound.
    Nov 22 2012
    Portland, Oregon
    Quote Originally Posted by gotmpower View Post
    That's why it's not a means to an end for me, I want more than stock sports exhaust but can't afford a $3000+ exhaust yet.
    Veteran Member Three Rings Sazexa's Avatar
    Jul 15 2017
    Colorado
    If you want "more sound" from your RS5's than just that ECS x-pipe, just have a ship weld up some pipes from the x-pipe back and remove the two rear mufflers as well. My S5's exhaust set up currently is factory headers, cats, and down pipes. Custom x-pipe, and then straight piping after that. No mufflers. Plenty loud when you want it to be, but nice and comfortable for cruising without being intrusive.
    - - - Updated - - -
    The price to have that done should be relatively cheap.
    Nov 22 2012
    Portland, Oregon
    Quote Originally Posted by Sazexa View Post
    - - - Updated - - -
    I as well as others would like to retain the vavled muffler feature.
    Jul 25 2011
    full exhaust system
    Apr 09 2018
    WA
    Quote Originally Posted by Beast View Post
    full exhaust system
    it's coming SOON
    Registered User Two Rings Stuart@VelocityAP's Avatar
    Jan 26 2018
    British Columbia
    You don't have to choose one or the other, you can do both in one shot!
    Our downpipes have an XPipe built in: http://www.velocityap.com/Audi-RS5-E...dirs5xpipe.htm
    Nov 22 2012
    Portland, Oregon
    Quote Originally Posted by Stuart@VelocityAP View Post
    Correct me if I'm wrong but doesn't that still leave the middle section with the resonator?
    Apr 09 2018
    WA
    Stuart, Don't make me drive up there and pick one up :D
    Delsangre, yes they leave the center one in, this is like an AWE but with an x for better flow.
    Nov 22 2012
    Portland, Oregon
    I just installed the ECS X-Pipe on my lunch break at work. (I work in a weld shop). In summary my 30 min break turned into a 1.5 hour install and I skipped eating.
    ECS instructions are basically bullshit unless you have a lift. There's almost no way to use a sawsall with such a low car on just ramps. So I took the whole rear section out including unplugging the valves and I unbolted all the hangar mounts from the floor instead of trying to get the rubber of lying on my back. Once out I made nice straight cuts and put it back in peices like the directions say. Re assembly was fairly easy but one hangar bolt also goes through the fuel tank strap.
    The end result is open downpipes is absolutely orgasmic and the X-Pipe really really wakes up the car. It can be louder as most already say and it's not super deep but it sounds awesome! I'll get back to yall about drone.
    Basically quiet is like stock, and flaps open sounds sooooo good!
    Established Member Two Rings croltean's Avatar
    Oct 11 2017
    2021 Nardo RS5, 2023 SQ8, 2018 SQ5
    Atlanta
    Just a word of caution - if you do go AWE non-res downpipes to stock cat back you may have some issues with car running. Seems like the non-res DP's flow better than stock and exhaust gets bottlenecked at the center resonator causing car to misfire and throw lean codes on Bank 1 and Bank 2. I could not keep it a solid idle. At least thats what I have experienced in my case. Running OEM DP with ECS X-pipe worked just fine as did AWE Non-res Paired with the X-Pipe.
    Apr 09 2018
    WA
    Quote Originally Posted by croltean View Post
    What were your thoughts on both the x-pipe and downpipe?
    - - - Updated - - -
    How does the x-pipe attach to the cuts? Do you weld it?
    Oct 11 2017
    Atlanta
    NON-Res DP + ECS Xpipe = Very Loud and Raspy paired with the OEM Sports Exhaust. Valves closed sounds stock.
    X-Pipe has exhaust sleeves the slide over both ends of the cuts to join them together. No welding required and completely reversible to go back to stock.
    Nov 22 2012
    Portland, Oregon
    No it ships with two of the same OEM Audi exhaust clamps that attach the center section to the downpipes. You make cuts, put the X-pipe up in place and tighten the now 4 exhaust clamps. Pretty seamless install.
    Apr 09 2018
    WA
    Awesome thanks to you both!
    Croltean, I definitely have heard both as very raspy. The nice thing about both is it gives you the full exhaust potential with non-res for the future. Would you recommend the first one as x-pipe or downpipe?
    Apr 09 2018
    WA
    OH awesome with those sleeves, you can just put the res section back on that's good to know.
    Oct 11 2017
    Atlanta
    I would do the x-pipe and call it a day unless you go full exhaust. Like I mentioned if you do non res DP’s on stock catback you may throw some lean codes as the exhaust flow is altered and you may have drivability issues. My RS5 did not like that set up. Currently I am running non-res and xpipe- I like how loud it is, but I hate the rasp. I am looking at AWE Track Extreme as it cuts down some of the raspiness.
    Oct 11 2017
    Atlanta
    Forgot to add- if you plan on installing the downpipes yourself. Save yourself the frustration and get the AWE DP tool. There is literally no room to get to the passenger side top bolt. Make sure you soak bolts in some penetrating oil prior the removing them.
    Apr 09 2018
    WA
    Thank you I have ordered the X-pipe!
    Jul 25 2011
    Ive been running this setup for 2+ years without any problems....
    Oct 11 2017
    Atlanta
    Mine didn’t like it at all. The car would stall at idle and got p0171 and p0174. Once I took out the center res and replaced with x-pipe all issues went away
    Jul 25 2011
    interesting. I have the VelocityAP valved exhaust ready to install thankfully
    Oct 11 2017
    Atlanta
    Nice! Been looking forward to hear what VAP sounds like.. im between Awe Track or VAP
    Apr 09 2018
    WA
    Yup now I'm between VAP and GTHaus, I'd take a look at them too if you're in the market for valved. Just waiting for next tax season
    Established Member Two Rings jay_c09's Avatar
    Dec 18 2016
    2013 Audi RS5, 2013 Infiniti JX35
    Anyone running VAP downpipes/x-pipe with Capristo exhaust?
    2013 Suzuka Grey RS5: Eventuri CF Intake, Capristo Exhaust with Non-Res Center Section, AWE Downpipes, VelocityAP Stage 1 Tune, KW HAS Kit, ECS 2-Piece Tru Float Rotors, EBC RedStuff Pads, Vossen 20x10.5" VFS-6.
    IG: LAUDI_RS5
    Jul 25 2011
    its going on next week I will have some vids up.
    My setup will be VAP valved exhaust (with optional Xipe in the centre instead of a resonator) with AWE Non res DP.
    Apr 09 2018
    WA
    Beast where are we at with the VAP?!
    Veteran Member Three Rings spense5's Avatar
    May 10 2018
    [I don't mean to thread hijack]
    Is anyone familiar with the Stasis exhaust system. I recently acquired a b8 s5 that had Stasis pkg installed. I'm not sure what it fully incorporates...I do have the drone from 800-2600 or so but its quite tolerable. I'm wondering what I should look at underneath and what could add just a little more growl but not being overly obnoxious and crackly. Thanks!
