Results 1 to 9 of 9
    Established Member Two Rings i8snitches's Avatar
    Mar 03 2018
    2018%20Audi%20S5
    GA
    Mixing e85 + 93 to get APR 100 Octane
    Ok so I have APR Stage 2 and curious if anyone has done the 1:4 mix of e85 with 93 Octane to get to 100 Octane. I've been rummaging around the B8 forums where a few have done this but closest I found was with stock tune.
    At this point it's just a question of, 'Is this possible?" or "You crazymad scientist you'll blow your engine.".
    Welcome some feedbacks and insight... Granted this is my daily driver so not sure my wallet can handle 100-octane other than for 1/4 mile and track runs.
    2014 A6 3.0T
    MODs: APR Ultracharger & DP (57.75mm/187mm) | Roceuro CAI for APR Ultracharger| AWE Touring Exhaust with resonated downpipe | APR CPS | Eurocode Test Pipe | Bilstein B8 Strut | H&R Sport Springs | 036 Control Arm Kit | Eurocode Sway Bar Kit and Endlinks | Jokerz Ported Blower
    UPCOMING: Custom TCU tune
    Sep 22 2013
    E35 should be good for 100 file, whatever you try, make sure to log.
    Veteran Member Four Rings bajan01's Avatar
    Jan 11 2018
    2018 VW Atlas, 2016 VW Golf
    Florida
    Quote Originally Posted by Dardan View Post
    I agree on the logging. I am running about 4 gallons of E85 per full tank of 93 and I did notice less timing being pulled on a 4th gear run. This is on my daily driver SQ5, EPL DP tune.
    Mar 03 2018
    2018%20Audi%20S5
    GA
    What are you guys using for logging?VCDS?
    2014 A6 3.0T
    Jan 11 2018
    Florida
    Quote Originally Posted by i8snitches View Post
    Ross-Tech VCDS and a laptop with Excel to analyze after.
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    you'll likely be fine. The shift-points of the A6 doesn't pose too much of a fuel system threat, however you may still want to purchase an Autotech HPFP rod just in case. The 3.0t fuel system runs into issues moreso after 6,500rpm - 7,700rpm zone (or higher depending on who sets the tune).
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Mar 03 2018
    2018%20Audi%20S5
    GA
    Well made the plunge and did the AutoTech Piston and new Hitcahi fuel pump... running e85 (4gallons) to every full tank... with the APR 100oct file
    major improvement and so far everything is operating efficiently. I am looking to the install the flex fuel kit to monitor... Anyone have experience with this kit: https://www.fuel-it.com/audi-s4-flex-fuel-kits/
    2014 A6 3.0T
    Established Member Two Rings BlueSteW8's Avatar
    Apr 24 2011
    Supercharger Heaven USA
    I know they are well respected, I've been looking at them and also Zietronix (? ) with an eye towards also adding the P3 vent gauge before getting the 100AKI file.
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    I've had the fuel it kit on my car for a few years. It's solid. If you have a gauge such as p3 there's a option so you can wire it
    Sent from my SM-G965U using Audizine mobile app
