Originally Posted by
Seerlah
To find out if your EMC is tuned, log your requested boost. If your ECM is requesting more than 11psi (AWM), then it is tuned. That will determine if you have a stock or tuned ECM. As for running rich with the tune, a clogged cat converter can make you run rich. Just another thing to consider and look into. If original stock, they are very restrictive and could be your issue seeing that it is like two decades old.
As for "calibrating" the ECM, there is no real calibration. What is necessary is to make sure the soft coding matches your current ECM. The soft coding would include numbers that let the ECM know that it is being used on a manual, automatic, no seat belt chime, etc. When you hook up your cable to read the ECM using proper software, write down the soft code number onto a paper. Then if you need to swap the other ECM in, make sure the numbers match. If not, simply input the number code you wrote down on paper from your current ECM. This number should remain the same for the ECM to function properly on your car.
I have disconnected the cat and run the engine to see if the -25% Lambda value would change and it did not.
I had an O2 sensor in the car that had exposed wires, one of which was the O2 heater wire. From what I understand the ECU supplies power to the heater.
The heater bit flip flops from on to off repeatedly regardless of driving condition or operating temp.
My conclusion is that the ECU may be bad from the short.
Got a new one coming and will see if it makes a difference on the O2 sensor.
I have a new O2 sensor in the car now.
