Results 1 to 15 of 15
    Feb 15 2018
    Unplug A6 3.0t PCV Valve
    Hello,
    I have a 2009 a6 3.0t and I think I have a bad PCV valve. I burn 1 qt a week....
    I also have a CEL that shows no code... I think it is likely oil burning related.
    Is it safe to just unplug the pcv valve? I heard that you only need it for emissions reasons.
    Could I unplug it for... track use... and then replug it for normal driving?
    And if so how difficulty would this be and what would need to be done to redo it again?
    - - - Updated - - -
    I heard old vehicles used to just dump it into the atmosphere
    Senior Member Two Rings juniorcruzer's Avatar
    Sep 28 2014
    2007 Suburban
    Center City Minnesota
    the PCV is under the supercharger, and requires you to take the supercharger off to get to it. There is a port that goes right into the supercharger that you would have to build a blocker plate for, and then two ports that come out the back that you would have to plug up, or run to a catch can.
    If you are somewhat mechanically inclined, it is not a terrible job to replace it.
    Jon
    2010 S4 3.0T, chipwerks stage I
    2010 A6 3.0T, APR Stage 2+, Roc Euro Intake, VMR V710 18x9.5 HyperSilver, 30% tint, A3 clear marker lights, LED Reverse lights, RS6 Grill
    Feb 15 2018
    Quote Originally Posted by juniorcruzer View Post
    Jon
    Okay - so in terms of work required it sounds almost identical to doing a PCV replacement - am I correct in this understanding?
    Feb 15 2018
    I was hoping I could just unplug something in a few minutes and that would be that
    Aug 24 2014
    Newport Beach, CA
    No, you can't do that on these cars. For one you'll get a vacuum leak as well as not allowing the crankcase to vent properly since you're removing a vacuum source. What you can do is add a catch can to help capture the oil that is being consumed, but it won't fix the root cause if you're consuming oil because your PCV is faulty. To replace the oil separator you have to remove the supercharger.
    Here's a system ECS put together for a catch can: http://www.audizine.com/forum/showth...tch-Can-System
    2024 M3 Comp xDrive
    Feb 15 2018
    Quote Originally Posted by christianb5s4 View Post
    Okay can you explain what the functional difference between a good and bad pcv is? I guess I just don't even understand
    Feb 15 2018
    Are there any tutorials for changing the PCV valve? I've never even changed my oil before...
    Aug 24 2014
    Newport Beach, CA
    The PCV aka oil separator removes the airborne oil vapors that are created by the engine and recirculates it back into the intake so it can be burned again for emissions purposes. This is the part number for the PCV: 06E103547AC
    I'm not finding the DIY I bookmarked specifically for the PCV, but the hardest part is the removal of the supercharger. Here's a bunch of stuff that outlines the general process:
    http://www.audizine.com/forum/showth...-Removed-(Pics
    2024 M3 Comp xDrive
    Feb 15 2018
    So I have been researching it and I think if I cut hose between pcv and intake and then block intake side and leave the other side open it will just blast that gas into the engine bay
    Is this true?
    - - - Updated - - -
    I think my PCV is stuck open
    Feb 15 2018
    CEL is gone - but a QT a week of oil = not good
    Fuck this PCV I want it out lmao
    Sep 28 2014
    2007 Suburban
    I would replace it, if not yourself, I'm sure there is a local VW/Audi shop that would be able to do the work for a reasonable price.
    Jon
    Feb 15 2018
    Jon
    How much do you think it should cost and what else should be done at the same time?
    Sep 28 2014
    2007 Suburban
    I just did mine, and I had to buy the crossover coolant pipe that goes over the top of the PCV as well as the oil pressure sensor. So mine was a little over $300 doing it myself. If you don't know when the thermostat and water pump were done, some say do those while you are at it because you have the super charger off, but honestly it only takes 15 minutes to get the super charger off, so not that big of a deal to me.
    Jon
    Aug 24 2014
    Newport Beach, CA
    I also recommend replacing this breather tube at the same time, it's virtually impossible to do this without the supercharger removed.
    https://www.ecstuning.com/b-genuine-...e/06e103207am/
    Long story short, if you're doing the oil separator/PCV, at a minimum replace the thermostat and this breather tube at the same time. I'd inspect your intake valves to see how the carbon build up looks because if it's a significant amount, this is the time to take care of it while the supercharge is off. Don't forget you will need all new injector o-rings, upper and lower intake manifold gaskets regardless of the other items since these need to be replaced each time you remove the supercharger.
    2024 M3 Comp xDrive
    Senior Member Two Rings cgfen's Avatar
    Dec 10 2011
    Vista, CA
    "So I have been researching it and I think if I cut hose between pcv and intake and then block intake side and leave the other side open it will just blast that gas into the engine bay
    Is this true?"
    LOL
    hope springs eternal
    Current rides
    2011 Audi A4 - Misanao Red Pearl over black (back in the garage)
    2010 A6 Avant - Grey over Grey - Supercharged!
    2009 911 C2S (997) - Nordic Gold over Cocoa, Chairman Meow's DD
    2008 987.1 Boxster - Guards red over black
    Gone, some missed more than others
    2016 Porsche GT4 / 2004 Porsche GT3 / 2000 Ferrari Modena – 3 pedal car / 2006 S4 Avant- 3 pedal! / 2014 R8 / 1996 911 C4S
    Lottsa steel-is-real roadie bikes.
