I wanted to post this as a new topic as it doesn’t relate specifically to vagcom.
My car will not connect to a state inspection machine, I can however, connect to with both vagcom and EPL. On the inspections machine (NH) the power light comes on but it won’t talk.
The only thing offhand I can think of is the gauges. I replaced them between this and last inspection but did have component protection removed. I was wondering if this could be part of the problem or if anyone has experienced this before.
I’m kind of at a loss. I did pull the ecu out when I replaced the clutch line cable but didn’t disconnect it. It was just laid over out of the way.
The port also works with scanners and the inspection machine has worked on other cars.
Any ideas would be great!
