Originally Posted by
Spawne32
transfer case? you have quattro, you dont have a transfer case
lols this explains why I couldn't find an answer!
After reading up on quattro, I still don't see the difference between a transfer case and center differential--both transfer power from the trans to the front and rear diffs.
jfo
No, there is a front differential that uses 75W-90 like the rear diff. The centre diff also uses 75W-90 oil but has a friction modifier added called Sturaco. It's only available at a dealer and is quite expensive. There are threads here about changing diff oil.
It's the same with certain transfer cases in Jeeps (again, failing to see the difference). Does anyone have a part number for this OEM liquid gold? I like to change my diff and transfer case fluid every 30k miles and my A4 is at 63k and I'm guessing has never had these fluids changed.
