Results 1 to 12 of 12
    Oct 24 2017
    1999 Camaro SS
    Windsor,Ont
    STM intercooler results
    Got a chance to install the STM intercooler in my car today and compared before and after as best i could with dragy.
    Car - 2018 RS3
    Tune - Unitronic 1+
    Fuel - Petro 94
    Wheels - 19 x 8.5 Konig ultraforms
    Tires - 245/35/19 PS4S
    Intercooler - STM
    Everything is Stock other than whats listed above.
    Stock IC results - Ambient temp 60 Degrees F - DA 1036
    STM IC results - Ambient temp 71 Degrees F - DA 1494
    So almost .2 sec and 2.5mph "recovered" in worse weather. Not bad!
    2018 Nardo RS3 - Unitronic Stage 2, STM DP, STM IC, APR Inlet + Tube, EMD Springs, EMD RSB, 255/35 PS4S
    May 03 2018
    11th gen Honda Accord Hybrid EX-L
    Jax, FL
    With hotter temp and higher DA, looks pretty good. Thanks for sharing. May go that way if Unitronic don't move their butt <3 Uni!!
    Dec 14 2009
    Houston, TX
    STM FMIC has helped a ton here in Texas and no doubt I’ll be in the 10’s this fall on Stage 1 93. DA’s here have been floating around 1800-3000DA in the middle of the afternoon with feels like up to 110 degrees.
    The first two pulls were done after 9pm at about 85 degrees the second set of 4 were done in the same spot but around 3pm at 92 degrees. Both are back to back pulls from one street light to the next. Also have 1/4 comparisons.
    No intercooler
    STM Intercooler Installed
    1/4 mile comparisons
    1 & 2 are with intercooler 3-5 are with out and you can see how close the runs are together.
    Without Intercooler back to back
    With STM FMIC
    May 03 2018
    Jax, FL
    Stage 1 or stage 1+? You indicated stage 1 93.
    So, safe to assume 1+, and since in TX, why wouldn't you be?!
    Any other mods?
    Wheels/tires, if so, spec's?
    Veteran Member Three Rings shivaswrath's Avatar
    Sep 21 2017
    NJ/CT
    So no turbo lag from larger IC? Those real world data are impressive.
    2017 RS3 | Xpel in the front & Feynlabs all around | WINCOS IR 30% F and 20% R | 245/35-19 Pirelli Sottozero Serie II for winters | I'm not modding this super amazing car so I'm going to list stupid $hit like RS3 All season mats and Blendmount for Escort Max
    Dec 14 2009
    Houston, TX
    Quote Originally Posted by comingabriel View Post
    Any other mods?
    Sorry, I should have clarified I'm not on Unitronic, I'm with Custom Code. I mainly have supporting mods, 034 suspension bits, PiperCross panel filter to be different, and OEM R8 wheels w/PS4S's which aren't the best for drag racing, but on the street they do fine.
    Oct 02 2017
    Quote Originally Posted by shivaswrath View Post
    you can tune out the midrange loss but, stock tune you're losing a good bit with a larger IC. from single dyno pulls you'll lose up to 20whp in the midrange. It's why a tune with IC is so important, so you can take advantage of it
    Sep 21 2017
    NJ/CT
    Quote Originally Posted by OE2 View Post
    Ugh I'm trying to get around tuning it....maybe the IE intake can even that 20 loss out
    Jan 24 2013
    Nice! Any vcds logs you can share?
    Email: [email protected]
    Call or Text: 914-243-1993
    Dec 14 2009
    Houston, TX
    Quote Originally Posted by Paul@SupremePower View Post
    I can maybe pm you some I took tonight, what were you wanting to see?
    Jan 24 2013
    Quote Originally Posted by Rocketsauce16 View Post
    You have pm!
    Oct 24 2017
    1999 Camaro SS
    Windsor,Ont
    How accurate is the engine torque value when logging with VCDS out of curiosity?
