I have a 2001 A4 1.8t AWM Quattro Avant. I've been having a really hard time diagnosing this one.
Runs rich -25% Lambda on group 107 when idle.
Using Ross-Tech VCDS for diagnostic.
While driving it's all over the place but stays in the negatives most of the time, sometimes at 0 sometimes within spec, often out of spec on the rich side.
When I first start the car it's on 0% and then slowly descends down to -25%
Is it true that a leak on the pressure side of the intake could cause the engine to run this rich?
I would think, especially at idle, that the engine would run lean, not rich.
I don't seem to have any obvious vacuum leaks, everything is where it should be.
Car seems low on power at low RPM. Turbo does engage, have not done any kind of boost level test, not sure what stock boost should be on this car or if that would be an accurate test.
I've been trying to figure this one out for awhile and have not been able to.
All the parts that have been changed on the car recently (with no change in rich condition):
MAF
Intake air temp
Coolant temp
Plugs and coils
Engine speed
Upstream O2 sensor
Cat to Turbo gasket
Suction pump valve assembly (hoses and check valves)
PCV valve
I did a test on the secondary air system, I did get an Abort result...could that be a factor? If so why?
I bought this car used and as far as I know the engine computer has a factory configuration, but I wonder sometimes if it's got a tune on it and that's why it's not running right.
Not sure what to do.
Anybody have any ideas or experience with this issue?
