Results 1 to 25 of 25
    Established Member Two Rings AudiMode's Avatar
    Oct 18 2011
    WA
    Dodge Hellcat Anyone?
    Any of you guys done any pulls against a Hellcat? Went for a ride in one yesterday and it's, as Chris Harris would say, absolutely mental. That much power from the factory is bonkers. What kind of setup would you need to pull on one? 3.0L w/ 770's?
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    I messed with one a while ago on the highway, no lined up pulls though. He wasn't getting away from me. For reference, here's 40-100mph
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    I'll let you know next weekend after S4RW. GoPro is coming along, and I'm sure there will be video from the side lines.
    Apr 07 2011
    Home of the mighty beaver
    I was in a half mile event with 4 of them. I beat all of them in the 1/4 and was faster than two of them in the 1/2 mile trap speed. Within .5 mph of the two faster ones.
    Aug 24 2014
    Newport Beach, CA
    ^Same here. At Shift S3ctor, my car trapped 155.07mph. The two Hellcats that ran (both modified) ran 150.85 and 155.01. My car has a similar setup to S4James and DieselElectric.
    2024 M3 Comp xDrive
    Apr 07 2011
    man i wish we had a full half mile.. these k24 cars are monsters in 4th and 5th...
    Aug 24 2014
    Newport Beach, CA
    I think our cars would do even better from a second gear roll or even a dig, Hellcats have big issues with traction off the line. They do best at events like the half mile where they can get up to speeds where they aren't traction limited.
    2024 M3 Comp xDrive
    Feb 23 2010
    Emmaus Pa
    4 and 5 in these cars rolls. 3rd and 4th don’t feel much different from each other either.
    Apr 07 2011
    thats cuz 3rd is too damn tall.
    Oct 18 2011
    WA
    I'm impressed to hear that your guys k24 cars can hang with them. If your b5 weighs 3300lbs and makes 500 hp that's 6.6 lbs per hp. The hellcat challenger weights 4448 lbs and makes 707 hp so that's 6.28 lbs per hp. Add in the all wheel drive advantage of the b5 and I guess it probably would be close!
    Nov 02 2014
    Winchester, VA
    Quote Originally Posted by AudiMode View Post
    I don't think a 500hp (crank rating like the HC) would hang.
    We're talking more like 600WHP, which is going to be right around the same CHP as the HC.
    Apr 07 2011
    no chance a 500CHP s4 will hang with a hellcat.
    Nov 02 2014
    Winchester, VA
    FWIW, a healthy k04 car on e85 traps right there with a stock Hellcat.
    More bench racing, I've got a 60-130 time of 6.9 vs the Hellcats 8.4.
    The one coming to RW is modified though, I think. Owner hasn't specified.
    Apr 07 2011
    possibly.. but a k04 car on e85 isnt 500hp crank.
    Nov 02 2014
    Winchester, VA
    I know that, my above 500hp comment was in response to the Audimode comparing crank numbers. I think he was confusing common S4 whp numbers with crank.
    Feb 23 2010
    Emmaus Pa
    I ran into a modified (had to be by the smell from the exhaust) Demon the other week in my B8. It was a massacre. He passed my while spinning. From a roll, I would like to see how my b5 would do, from a dig, you're not touching one.
    B9 S4- EPL/AWE
    Sep 11 2009
    NE
    My brother in law has hellcat and it is a monster to drive. Limited traction even on 325 radials. Launches in second gear and it just spins wheels all the way to 60-70.
    Having said that we did a couple of roll races with my 2.7 tial 770 (600ish whp) allroad and we were head to head more or less, maybe I was losing a bit sometimes.
    We don't have a good roads here so we couldn't go really fast but I was at an advantage in shifting department because for this kind of roll "race" I only need one gear, sometimes two depending from what speed we start as I can just do the whole thing in 3rd gear already brake boosting while honking :)
    Anyway, crazy car and it shows exactly what supercharger can do although let's not even start talking about the displacement of its engine lol.
    Aug 24 2014
    Newport Beach, CA
    Those blowers are almost the same displacement as a 2.7 lol, if I'm not mistaken the Hellcat blower is 2.4 liters in capacity.
    2024 M3 Comp xDrive
    Established Member Two Rings Alchemy's Avatar
    Jan 14 2018
    North Carolina
    Yeah, can confirm that these factory freaks are bonkers, ran a few roll races with one in my PJ k04 car and was dusted fairly quickly, however as soon as we hit some curvy backroads the tables turned, those big boats just can't hang in the high speed corners.
    It's really cool how far manufacturers are pushing the limits now versus even 10 years ago but I will fondly refuse to drive anything with an automatic transmission even if it's the errmerrgurd DSG tronomatic yada yada yada.
    Driven to Succeed
    Mar 22 2013
    AK
    Challenger Hellcat is available with a manual transmission, Charger is Auto only
    Veteran Member Four Rings CJ_'s Avatar
    Oct 27 2014
    Flag/Phx, AZ
    Quote Originally Posted by S4James View Post
    Pj k04 on E85 is easily capable of 500bhp
    2001.5 Silver S4 Avant - 6spd swap + BW K04s (Current)
    2001.5 Santorin S4 Sedan - SRM k24 build (Totaled)
    IG: CJ_s4
    Apr 07 2011
    Quote Originally Posted by CJ_ View Post
    I meant its way more if done right.
    Feb 23 2010
    Emmaus Pa
    Think he means that’s low for a K04 car on E
    Edit: Too slow on the draw
    Oct 27 2014
    Flag/Phx, AZ
    Ah read that wrong..
    IG: CJ_s4
    Nov 12 2015
    Oregon
    Just for fun I'll post up today's fun. I'm in a b7 s4, but still...
    All i know is it was a challenger SRT with what sounded like a dsg transmission (based on the farts it emitted upon hard shifting). Kept revving his engine and downshifting next to me. I figured why not. It was head to head until 130 and I left him. What the hell....
    Sent from my SM-N920V using Audizine mobile app
    My build log
