Results 1 to 22 of 22
    Jun 14 2007
    2000 S4
    Connecticut
    Question Front Bumper Woes
    Guys,
    Earlier this year I bought some new fender clips to hold my bumper on because I wanted to re-align it to the fender as it had gotten pretty out of whack over the years from trying to rip it off... Since replacing these clips, another forum member has graciously helped me twice now try to get everything back together, but over some bumps on my commute the bumper has been popping off the clips. Where is the best place to throw some screws to avoid this from happening? I have these quik-latches that this guy is going to die if I install, but I am moments away if this keeps happening :)
    Thanks for any tips!
    Aug 24 2014
    Newport Beach, CA
    If you replaced the clips that the fender attaches to, the next place to look is what shape the actual 'hooks' on the bumper itself that attach to the clips look like. These also wear out and create a poor connection with the clip.
    2024 M3 Comp xDrive
    Jul 04 2012
    Woodbridge, VA
    yea not a whole lot you can do once the bumper side clips get worn out. I would say give the car side clips another go first. Get your gaps right and see how that goes. If all else fails, you can look into the quick disconnect latch system. works really well. Ill sell you my kit I never used.
    Jun 14 2007
    2000 S4
    Connecticut
    ^ Right, the clips on the bumper are attached to the frame of the bumper itself, right? It doesn't look like those can get replaced. That would make sense that those wear down too, I didn't think of that.
    I already have the Qwik Latches, just never installed them... However, this is making me want to! I may just do it because I don't personally think it's a terrible look and the function of them is hard to beat.
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    The clips on the bumper are molded into the bumper aren't they? It's been a while.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by CELison View Post
    Yeah, looks like that's the case. I am actually happy that the best bet considering I have them in my possession already may be going to Qwik latches. I might as well use them since I bought them. Just something about drilling through the bumper that sends chills down your spine, but at this point whatever!
    Feb 23 2010
    Emmaus Pa
    For whatever reason the hoods always look crooked on these cars. The pass side looks high than the driver. Anyone else notice that?
    Veteran Member Three Rings Calif_Kid's Avatar
    Oct 14 2006
    2001 A6 6 spd, 2001.5 AWE stage3 Nogaro 6-speed (sold), 2000 Honda Civic racecar (sold)
    Sunnyvale, Calif
    Quote Originally Posted by christianb5s4 View Post
    Are these the things that are attached to the bumper cover? https://www.ecstuning.com/b-genuine-...ht/8d0807284a/ I've pulled my bumper off a few times, but never had to replace them. Anyway, I think that they're bolted to the bumper cover right? - Jim
    Veteran Member Four Rings cjt671's Avatar
    Dec 14 2014
    B5 S4 sedan, 2018 Q5
    PNW
    You can adjust the hood height
    Established Member Two Rings warrenzo's Avatar
    Dec 06 2016
    2000 S4 Black, 2001 Ram 1500 Off-Road
    Lethbridge, Alberta
    Try pulling the bumper further forward on the two allen bolts under the front grill guards, pulling it forward seems to help keep those clips tight. If it's pushed too far back, the bumper cover wants to bow out and push back forwards.
    May 20 2012
    San Jose
    Those go on the fenders. They clip onto other pieces plastic welded to the bumper cover. I don't see those available separately from ECS.
    Quote Originally Posted by Calif_Kid View Post
    Dec 05 2007
    What's wrong with quik latch? Been running them on my bumper for a few years now, albeit A4.
    Ripped the bumper off from driving the front over those cement curb blocks. Backed out and it destroyed the bumper clips. Quik Latch worked for me. Bonus, push two buttons and bumper comes right off (stays just fine without stock hardware that bolts to bumper shocks).
    Veteran Member Three Rings ElementR's Avatar
    Nov 23 2013
    2016 Stg 2 S6, '93 Mustang Cobra Twin Turbo 347cid, '01 B5 S4 Tial 605's
    Grosse Pointe, MI
    FWIW - it can be tricky to get the bumper to stay put on the factory clips in the fender area...my experience is that it's best to have the headlights out while install the bumper. Be sure you get the lower clips to latch and then the upper clips. If I ever tried to seat the upper clips first, the lowers wouldn't latch and the bumper would not stay attached.
    2001 Silver/Black S4, Built engine, Tial 605's @25psi on 93 oct, ET Spec Tune, JHM FMIC, JHM full trans rebuilt/upgrade, 3" SS dp + CBE, Vast intake + bipipes + tune, ST Coilovers, Hotchkis Swaybars, RS4 wheels and interior goodies.
    2016 Silver/Black S6 Sport Package, IE Stg 2 E85 & DSG tunes, IE intake, ARM DP's & Mid-pipes
    Veteran Member Four Rings PwrWgn's Avatar
    Sep 14 2013
    Just like my seatbelts! I couldn't find the bolts to reattach them so I just zip-tied them in! Nobody can even tell the difference
    Veteran Member Four Rings slowSfaux's Avatar
    Apr 26 2015
    Phoenix, AZ
    Quote Originally Posted by PwrWgn View Post
    This reminds me of an episode of roadkill. They seriously used a zip tie to keep their steering wheel from coming off the splined shaft, and it actually slipped through tech inspection!
    Dec 06 2016
    Lethbridge, Alberta
    I hope those guys don't kill themselves one day - because roadkill
    Senior Member Two Rings Isaac313's Avatar
    Aug 15 2017
    2008 Ford F350 Diesel - 2000 Audi S4 - 1994 Ford F150 Lightning
    Michigan
    The big molded slides on the bumper side of things can be replaced. They are effectively glued in with some tabs. You'll have to cut the glue out of the slots but it should come out alright. I can check on one of my bumpers when I'm home but you should be able to find a busted bumper for zero monies and steal the slides.
    May 20 2012
    San Jose
    What did you glue them with?
    Nov 03 2011
    All Over!
    If the claw part of the bumper brackets are worn, they will keep popping off the plastic fender retainers.
    Rather than fix quick release bits to keep the bumper in place, I would rather buy a bust S4 bumper, remove the claws, and bond them to your existing bumper. Failing that, I would replace the entire bumper.
    1986 Type 85 Audi 90 quattro
    Veteran Member Four Rings jaychen's Avatar
    Feb 19 2011
    Earth
    I'd use quiklatches before shelling out 800 for a new bumper. That's just me though.
    2000 Achat S4
    Nov 03 2011
    All Over!
    Quote Originally Posted by jaychen View Post
    If you like your bumper fastenings visible, sure. To me, it looks too much like a road car with rally car looks, sans the rest.
    Aug 15 2017
    Michigan
    We can't be too picky when bumpers are up to $1100 and backordered anyway....
    @oppositelock if you take them apart you can see the tabs and you'll have to cut the glue out and then use some sort of epoxy to put them back in. It's not super hard. Still looks oem without putting in visible quik latches which I definitely don't prefer personally.
