**Sorry if I wasn't clear, Blower is still on the car, will be removed at best, 1 week, most likely in 2 weeks. Deposit will be accepted if you want to make sure to grab it.**
Ported charger TVS1320 :
- Enhance throttle response
- Gives approx. 20-30whp and 20lbs of torque from downlow (2k rpm) to redline. move the curve up which is nice addition
- Reduce IAT
So what are you getting ?
- Chaos Port job (950$)
- Rebuild blower (350$)
- CTS pulley (150$)
- Complete Core (500$) (missing intercooler core. you will need to swap yours)
Total : 1950$
Now, shipping to Canada is 200$. So Grand Total of 2150$ USD = 2780$ + 15% custom, taxes and duties = 3200$ CAD !! Freakin currency and taxes boost the price quite quickly isn't lol!?
+ Theres no downtime to get your blower. I waited 6 weeks to get mine. And you avoid having to ship back your blower to the US which cost more $$. Resell your OEM for 500$ish
** The supercharger have approx. 300 km on it. Its fresh!
My price : 2000$ CAD **SOLD **
Q.1 : Will you ship to USA ?
Answer: Yes, shipping will be about 100-150cnd with insurance
Q.2: What Port job is that ?
Answer : That's the best port job Jokerz has to offer right now. It's latest and most extensive one. The ''chaos''
Q.3 : Jeez, that's '' Expensive '' !
Answer : Well, modding follow a marginal curves, when you get to a certain level, every extra advantage/HP cost more than when you start from stock, that's with any car on the market.
+ it's also a maintenance item. To think that your supercharger oil has a lifetime span is non-sens. It's not a bad idea to do some maintenance work on it (especially if you have more than 100,000km on your unit) So, it's a 2-1 mod, you get performance, but your also checking off one item off your maintenance list (caring for your supercharger all in all).
Q.4 : What else do I need ?
Answer : Personally, i was told, and this is what I did, to only have the 6 intake seal swapped. Everything else would be fine. You will also need new oil. You can either order 2 bottle of GM oil for 10$/118ml or Audi S/C oil at 40$/155ml. You will need 155ml. The cobalt use the same S/C so its safe to say that the oil is compatible.
Also, if you are paying a mechanic to do it (like i did), while your there, you can also have the PCV valve and thermostat swapped as it barely cost you anymore to have them swapped. Finally, take a look at your carbon build-up, might be due for a walnut blasting. All in All, you could end up saving 200-300$ in labour if you do it all at once which, again, reduce the overall price of this mod to make it much more acceptable and fair.
Q.5: Why your selling ?
I consider selling the car and that was impulse buying. My loss your gain !
Q.6 : Whats the lowest will you go ?
Why would I set a price if I was willing to accept less ? Respect it. Thank you.
