Originally Posted by
speedyp
With the OBDEleven you can change the setting of the fob where for example you need to hold it down for 3 second for the boot to open instead of 1.
The ODBEleven looks like an interesting device. I have to see if my Android tablet can do this. I don't use Android for cellphones, so far, but the tablet may be able to do it.
I will go talk to the local Audi service and see if they can make these adjustments.
Diokhan
I'm pretty sure "disable rear lid handle" does just that - disables the outside handle button. Have you tried unchecking "open with convience key" and pressing the trunk button? If that doesn't do it, then you may have to get in the habit of placing your smart key in that little slot to the right of the shift lever instead of keeping it in your pocket.
Fun fact - I run into the same problem as you sometimes while sitting on the couch at home. The garage is on the other side of the wall and there's been several times where I've walked into the garage and found the rear lid open.
In my case the car is parked outside and getting rain in the trunk, and on the electronics in the trunk, was not a happy event.
I tried the disable rear handle option. This didn't seem to have any effect at all on the key fob OR the trunk release on the back of the car.
Perhaps I have to do something to activate the change? I did the X, then hit back button, then shutdown the car, locked the car with the FOB, then opened the trunk with the FOB, closed it, and then opened the trunk with trunk release on the back of the car.
Did i skip a step?
