Function: They sweep across rather than "blink"
Stock Mirror Housing Signal (the thin piece between upper and lower housing):
Aftermarket Installed:
Stock signal above Aftermarket (Backside):
Note: The part that illuminates and is normally visible is fairly slim...and more of the part itself is underneath the upper and lower housing)
Stock signal above Aftermarket (Front):
Quick Video:
Info:
Source - eBay. (Seller "creativeonline100") Listing was called: "For Audi A3 S3 RS3 Dynamic Flowing Side Wing Mirror Indicator Repeater Blinker"
Country of origin - China (Shipping was a few weeks)
Quality - yet to be determined
Fitment - plug and play - no modification to housing or part needed
Price - Varies (under $100 USD depending upon reseller) - I paid approx $75 shipped for the pair.
Installation difficulty - 6 (1 to 10 scale)
Installation time - 1st one... 30min 2nd one 10.
Tools needed - Torx bit + extension, plastic pry tool or equivalent, guts to pry on mirror housing
Thoughts:
Installation was a little tedious but I took my time and figured it out. Most Youtube vids of A3 mirror housing removal don't include an extra power connector that I found on the RS3, however disassembly was easy once I figured it out how the connectors unclip. Approx 5-6 torx screws to remove/loosen.
The sweeping motion looks good (to me) day or night
As you can see...when not illuminated it blends well with the stock housing. The lights don't seem wild or blinding. From the driver perspective ... the stock part has a transparent square notch on end of the mirror so that you can see the "blink" when the signal is on. On the aftermarket, its smoked and you can still see the light after each sweep however since it falls slight short of the outside edge, its not as bright and pronounced. I personally prefer it this way because I thought it was a distraction in stock form.
Going to see how they look at night tonight and keep them on for a bit to make a final decision.
*Added new video*
