Well, I went the 320 mm route and I can say that it’s definitely an improvement from stock for sure. You’re essentially going from a one piston 282 piston front brake system so you’re getting more even wear as well as overall better pad distribution on to the caliper. I don’t track the car as it’s my daily driver so I just wanted a moderate upgrade without breaking the bank and this definitely fit the bill! The other nice thing is that you don’t have to switch out the rotors given the 320’s fit on our OE setup. So if your rotors still have considerable life on them, a thorough cleaning and double check for any warping and you’re golden! I went with Centric Posi-Quiet pads up front and Akebono pads in the rear. ECS stainless steel lines all around, good quality brake fluid, got the Schwaben mini fluid pump kit which worked great so you can do a one person bleed. Happy with how they turned out.
As for performance, it’s not as if you tap on the brakes and suddenly you’re head-butting the windshield type of stoppage. I’d say it’s a subtle but appreciable steady stopping power. With the OEM calipers, if I were going pretty fast and had to really stop, I have to basically slam that pedal to the floor. Even then, I still felt like gosh it definitely needs more. The 320s feels more reassured but you still gotta get on it early. It just feels like it took at least that element of “ oh oh, I don’t have any more leeway to push that pedal down any further!”
I can’t speak for the 345 mm calipers since I never set those up on my car. Based on what others have posted in the past, stands to reason that it would be the logical next step up versus the 320 mm. How much more so? Couldn’t really tell you. If I had to do it over again, I’d keep my eyes out for a used set of 345’s. So long as they aren’t damaged/leaking, I’d have them sand blasted, powder coated, and new caliper kit for the gaskets done.by replacing the gaskets. It stands to reason that if given a choice and money isn’t s big factor, you’ld have to go with the 345s. It basically comes down to your wallet and what you’re trying to achieve. If you’re planning to track the car want something with really substantial power to stop on a dime? If that’s your answer then definitely the 345‘s. If you’re more like me, just puttin’ around town, commuting, running errands, heading out of town on a rare occasion for a weekend getaway, then the 320s are definitely serviceable imho.
Here’s how mine came out.
