Results 1 to 8 of 8
    Veteran Member Three Rings Audi_Andrew19's Avatar
    Nov 02 2016
    Washington, D.C.
    LED Fog Lights B8
    I know this has been asked before, but wanted to hear the quick and dirty of what LED fog lights people are running on their S4?
    Looking for a crisp white to match the headlight/DRL as best as possible without spending a fortune. Open to any options.
    Senior Member Three Rings j23a45m's Avatar
    Feb 07 2018
    19’ Qx60, 16' s1000rr, 15’ S4, 12' X5, 10' A3
    Lacaster, Pa
    Philips X-tremeVision
    [B]'15 S4 - Sepang Blue|DSG|Sport Differential|MMI|B&O Side Assist|ECS Trans Mount|ECS F/R Diff Mount|MercRacing Hx/ Divorce kit|AWE Touring Exhaust 102mm|Apr Open Carbon Fiber Intake|Iabed 82mm throttle body |35% Tint|3000k Fog LED's|OBD Eleven Mods|Macan 4-piston brembo calipers|Unitronic Stage3 Ecu/ stage 2 Tcu|Custom clear lense and painted Headlights|Ecs carbon lip and rear diffuser|Airlift 3P/H| 10.25 Rsnav|034 Track/Street density/ Sway bar| [/CB]
    Senior Member Two Rings juniorcruzer's Avatar
    Sep 28 2014
    2007 Suburban
    Center City Minnesota
    I went yellow with mine, and bout the ones in the link. they make a white version as well.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Jon
    2010 S4 3.0T, chipwerks stage I
    2010 A6 3.0T, APR Stage 2+, Roc Euro Intake, VMR V710 18x9.5 HyperSilver, 30% tint, A3 clear marker lights, LED Reverse lights, RS6 Grill
    Nov 02 2016
    Washington, D.C.
    Quote Originally Posted by juniorcruzer View Post
    Jon
    Do you have any bulb out lights or anything?
    Sep 28 2014
    2007 Suburban
    Quote Originally Posted by Audi_Andrew19 View Post
    They work on my B8 without issue, and been on there for a couple months now, but give a bulb out on my C6.5.
    May 27 2009
    NH
    Philips 12834UNIX2 X-tremeVision LED Fog Light, Fits Fog H8, H11, H16, 2 Pack https://www.amazon.com/dp/B00U2NHLTI..._1kZcBbS3DWTKT
    35% off coupon right meow
    Nov 02 2016
    Washington, D.C.
    Has anyone taken a look at these?
    SEALIGHT H11/H8 LED Fog Lights Bulbs, Upgrade H16 LED Lamps DOT Approved, Cool Xenon White 6000K, 1 Yr Warranty (Pack of 2) https://www.amazon.com/dp/B07C985NXZ..._6NbdBbHVGGYCJ
    SEALIGHT H11 LED Fog Lights 38 SMD High Power H8 H16 Headlight Bulb for DRL or Fog Lights, Xenon White H11 LED 2 Yr Warranty Extremely Bright 6000K https://www.amazon.com/dp/B07CCG3XT4..._EPbdBbBE7C9MV
