Results 1 to 7 of 7
    Junior Member Two Rings
    May 20 2018
    IE, CA
    2015 SQ5, lower control arm bushings leaking?
    I picked up a 2015 SQ5 from carmax and had a PPI inspection done by local Audi dealership. mechanic reported that the bushings are leaking and the control arms (both sides) need to be replaced.
    another other Audi dealership did the recalls on it a couple days later and did not note any suspension issues. I asked about what the other dealership said and the service writer said that it doesn't have oil-filed bushings so they couldn't be leaking.
    who's correct here?
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    The latter. Bushings don't leak.
    Aug 13 2017
    Phoenix AZ
    Likely Motor mounts leaking
    Mar 13 2014
    Newcastle, England
    There is a hydro mount on the front suspension guide that they could be referring to. Its the arm at the rear of the hub that ties it to the subframe. The arm is part number 8R0407693D and the hydro mount is 8K0407183F if you want to look on a parts diagram to see which part I refer to.
    The wishbone runs two rubber bushes which wont leak.
    I have seen the hydro mount leak on my SQ5.
    Euro SQ5
    C6 Carbon Interior, Exterior and Engine Bay
    Custom yellow stitch and yellow seatbelts
    StillStatic/AH Exclusive Race H&R with custom Air bags (25" ground to fender)
    Aiflift 3P Management
    C6 Carbon Chassis mods
    DTUK Tuned 370Bhp 774Nm
    Rotiform DUS 22x10.5
    May 20 2018
    IE, CA
    IanSQ5, yup.
    I talked to the service manager last night and he had parts look this up. per my VIN#, apparently the curved control arm does have a hydraulic bushing,
    8K0407183D
    it's part 8 here , http://catcar.info/audivw/index.php?...NDA3MDA2MjA%3D
    so, now I get to have carmax replace them during the 30-day no-cost warranty.
    Mar 13 2014
    Newcastle, England
    TBH the parts aren't expensive, it would be the labour strip down that would make the job costly. At least they are doing it under warranty
    Euro SQ5
    May 20 2018
    IE, CA
    Quote Originally Posted by IanSQ5 View Post
    Yup, Audi quoted $1k to replace both control arms . Carmax is ordering the parts now and will do the repairs when they come in.
