720 RPM, 18.8% engine load, 2.50 g/s mass flow. Which seems low.
Then I slightly pushed the gas pedal until I achieved steady RPMs slightly higher than idle:
920 RPMs, 15.0% engine load. RPMs went up, load went down, is that normal? And oddly enough, MAF again reads 2.5 g/s, although I have clearly seen it go up to ~3.5 g/s in the 880-980 RPM range. This particular value could be a glitch, I guess.
On top of that, my engine is vibrating at 720 RPM (its idle after warming up). The vibration is not severe, and repair shop mechanic told me it's normal (the shop specializes in VAG). Still, Idon't think it's normal. The vibration disappears at ~800 RPMs. It's clearly produced by the engine block itself. I've got brand new original engine mounts, all three of them.
As you can see, I was also monitoring misfires, and didn't see any.
So, what do you think about these MAF readings? And what's with the engine load figure? And could any of this be related to the vibration that's starting to get on my nerves after 3 years owning this car?
