Results 1 to 30 of 30
    Established Member Two Rings BierJager's Avatar
    Apr 28 2017
    2015 Highlander
    Michigan
    Angry Oil level sensor fine is actually the hood open switch
    Two oil changes ago, our 2016 3.0T showed low oil and I asked about adding some here. I believe most posters said don't add any it's the sensor. I had it changed and the dealer said he didn't see any problem with the oil level and not a big deal. We went 10K miles after that without any further low oil notification.
    I had the oil changed again about 4K miles ago ( 6K to go ) and about a week ago, the low oil comes on again. I figured adding 1/2 a quart would not hurt just to see what it would do. Upon startup, the warning came up that the oil level was too high, please reduce oil level. We ignored that and drove another 250 miles or so. It came back shortly thereafter. Today as I'm sitting at the bank in auto-shutoff mode ( car not running ) the oil message turns red and says it's very low on oil.
    So I'm thinking it's time to replace the sensor and it should be under warranty at 26K correct? Or will it simply happen again later with a new sensor and I'm better off just getting a dipstick and ignoring it?
    Veteran Member Four Rings SDV325's Avatar
    Jan 20 2014
    Calgary, AB
    It amazes me these engines do not come with a dipstick. First "mod" i did, always good to check the physical level yourself.
    And yes warranty that.
    2016 Audi SQ5 | Technik | Glacier White | Magma | Black Optics | Beaufort Inlays | Roc-Euro | Revivify Graphene Pro | EPL Stg 2 | Eurocode USS | MOOG Endlinks |
    2014 Audi SQ5 Estoril- STOLEN / RIP
    2015 Toyota Rav4 - Family Wagon
    Aug 17 2010
    Vancouver, BC
    Agreed you need the dipstick mod for peace of mind but having said that, the oil sensors on both my S4 and on the Q5 3.0T have been relatively accurate. One good thing about two 3.0Ts in the garage, you only need to buy one dipstick!
    2011 S4 (Cdn Spec) premium, 6MT, Quartz, Eurocode SS, APR Ultracharger, DP Stage 2 & CPS, Carbonio intake & exhaust, Ported S/C by Matty
    2013 Q5 3.0T S-line, EPL Stage 1 (the missus' car) 2007 RS4 (sold)
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    My second oil-level sensor has failed. The first one under warranty, but this one. . .no such luck.
    Get a friggin' dipstick 100%. I did when the first one failed so now, I don't have to panic.
    My oil level is fine. Now, I just want to disable the damn thing.
    Get yours warrantied, and ask if it has it's own warranty since they are known to fail.
    Junior Member Two Rings
    Jan 21 2018
    SWFL
    Anyone have a P/N for the dipstick? 2012 3.2 here...
    Thanks,
    Apr 28 2017
    2015 Highlander
    Michigan
    Quote Originally Posted by KDuniverse View Post
    Thanks,
    You beat me to it. Was gonna search the zine for it but if anyone happens to have it handy, please post it up.
    My wife is all nervous about the warning light and I told her there's no way it's actually low on oil.
    How ridiculous is it this car, which has a warning on it not to overfill it, does not come with a dip stick and instead relies on a sensor.
    Also is there any known situation where the ECU will put the car into limp mode, or disable the motor due to this sensor? I thought not, but thought best to ask.
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Quote Originally Posted by BierJager View Post
    This is the correct dipstick for the 3.0TFSI engine
    https://www.ecstuning.com/b-genuine-...ck/06e115611h/
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Apr 28 2017
    2015 Highlander
    Michigan
    Quote Originally Posted by MSq5 View Post
    UPDATE:
    The car was low on washer fluid at the same time as the low oil indicator. Last night I bought a gallon at Menards and filled it in the parking lot. As soon as I started the car, low oil indicator is off and has not returned since. No errors this morning with one funny exception. My wife came running to me saying "now I can't get the seat to go forward!" as if to say there's some kind of electrical problem. I quickly discovered a phone charging cable had fallen into the screw drive in the seat track and was FUBAR.
    I do find the coincidence between the washer fill and the low oil indication interesting. Perhaps they share a common somewhere. I'm getting the dipstick and skipping the dealer visit.
    Apr 28 2017
    2015 Highlander
    Michigan
    It's back on. Apparently coincidental that it went off after I refilled the washer fluid.
    Dipstick ordered. I'm not likely to bother scheduling a dealer visit specifically for this problem in order to have it warrantied either.
    Just going to get my EPL tune on it and ignore the message until it goes back to dealer for next oil change.
    Apr 28 2017
    2015 Highlander
    Michigan
    Dipstick arrived and it shows the oil slightly over filled of course. The oil level warning goes off and on randomly now and I like knowing that I can just check it if I really think it's low. How big a deal is it to be overfilled by about 1/2 a quart? I can't imagine it's a major issue unless somebody confirms otherwise. I have been imagining taking a large syringe and some tubing to suck out some of it through the dipstick tube somehow.
    Feb 14 2017
    Gulfport, MS
    What is disturbing is that Audi knows that the oil level sensor is erratic and unreliable, yet, they continue to omit an inexpensive $25 dipstick. I was absolutely stunned when, after getting erratic levels, even right after an oil change done personally, I went to the dealer to buy a dipstick and was flatly told "we don't have one - use the MMI oil level."
    Well, we know they do have a dipstick. Why they choose to claim they don't remains a mystery. I guess they want us to let them do the oil changes and just hope for the best. And when it gets bad enough, sell and install more sensors that don't read accurately.
    For those reading this, just protect yourself and buy the OEM dipstick Audi left out. Yes, there is one.
    Apr 26 2014
    DFW
    Did it, done it, dude it.
    Now, I want to know how to completely disable that mofo.
    Nov 08 2014
    '14 Quattro A4
    Santa Cruz
    Vagcom coding I'm sure has that option.
    Steve
    '15 SQ Monsoon
    Apr 26 2014
    DFW
    So, does anyone know how to do it, where it is in VCDS?
    Apr 28 2017
    2015 Highlander
    Michigan
    What about some sort of pigtail connector that goes in place of the sensor and has a resistor or something to fool the ECU? I know nothing about the sensor or wiring but maybe others here have more knowledge and can share if this is possible.
    Nov 08 2014
    '14 Quattro A4
    Santa Cruz
    Quote Originally Posted by SQive View Post
    probably just needs to be set to 0 in the green menu
    Steve
    '15 SQ Monsoon
    Nov 08 2014
    '14 Quattro A4
    Santa Cruz
    However since it does bus communications when it shorts out it can take down the bus (and they have on the BMW's), so after uncoding might be best to unplug it.
    /car/carextdevicelist> oil level gauge uncheck
    5.01 shows it
    Steve
    '15 SQ Monsoon
    Apr 28 2017
    2015 Highlander
    Michigan
    Guys note above when I said I filled the washer fluid level and then it read just fine for awhile?
    And now I find this on youtube - https://youtu.be/SNeu1o0XRY0
    This does look like an older model but the hood open sensor switch apparently shares circuitry with the oil level sensor.
    If the switch is defective or having a problem it might be the culprit and not the oil level sensor. I opened the hood to add washer fluid and problem was gone when I closed it.
    Perhaps there's a relation here. I plan to look into this when I have a chance.
    Apr 28 2017
    2015 Highlander
    Michigan
    UPDATE:
    Yesterday we hop in the car and the low oil level alarm goes off again after I start it. I leave it running, pop the hood release, hop out and open and close the hood. The message was immediately gone. Oil level sensor shows oil level still full. I plan to find that switch as shown in the vid above and try cleaning it or messing with it, and if this continues, replace it or maybe just shunt it closed.
    May 21 2010
    I had this in my 17. Light came on ...added a litre. 5 days and 500 miles later it comes on again so i add a litre and book a service appt.. Its over full and sensor is bad. Sheesh.
    Apr 26 2014
    DFW
    Gentlemen, I have confirmed your suspicions about the hood switch being involved. The ol' oil-level sensor light came on again today. I simply popped the hood and closed it and voila! The oil level is perfect. I think we should make a big stink about this with Audi. I mean come on. . .no dipstick, and a common problem with their electronic measurement system. I could see someone running the engine out of oil and it seizing up after crying wolf so often. Audi would say it's not their fault, but I'd be willing to testify in that courtroom. Audi, fix your shit or send everyone a free f'ing dipstick, you dipsticks! -end rant-
    Apr 28 2017
    2015 Highlander
    Michigan
    It's particularly aggravating when you consider the relatively insignificant cost of that little switch compared to the potentially expensive damage that could result from relying upon it. But...it's not like it's an ignition switch that turns off the car while you drive or anything.......
    Deactivated Two Rings
    Sep 22 2017
    TN
    Is there a P/N# for a dipstick for a 2018 Q5 2.0T?
    Sep 11 2015
    2003%20VW%20Jetta%201.8T
    Western Mass
    Quote Originally Posted by blchandl2 View Post
    Did you find a part #? I have a 2016 Q5 2.0T and cannot seem to get a straight answer for a part #
    Sent from my SM-G960U using Tapatalk
    2015 Mythos Black Pearl BO 6MT S4 P+ | 19" peelers | Nav | Carbon inlays | B&O | Sport Diff | Nappa
    Mods: 20% tint | EPL | OEM Audi Sport plate frame | HOEN fogs |ECS 10/12.5mm Spacers | Hardwired radar | ECS Trans insert | CTS intake | AWE Touring Exhaust - stock DPs | H&R OE Sports + Koni Shocks | Eurocode F&R Sway
    Sep 22 2017
    TN
    Quote Originally Posted by Rbb1485 View Post
    No still looking. I know the one from our Q3 does not work.
    Oct 17 2015
    Hilton Head Island, SC
    Interesting thread. Is there a dipstick available for the 2.0? How hard to install?
    Veteran Member Four Rings choppstixxx's Avatar
    Apr 24 2017
    2016 Audi Q5 3.0T Premium+/2003 Honda S2000
    Hilton, NY
    Back when I had my B8.5 A4 w/the 2.0T, I used this from ECS and it fit perfectly.
    2020 Manganese Gray Metallic VW Arteon SEL Premium R-Line
    2003 Berlina Black Honda S2000
    2004 Crownline 202 LPX
    2016 Glacier White Metallic Q5 3.0T Premium+ S-Line 1 of 589 *RIP*
    2013 Moonlight Blue Metallic A4 Quattro Premium Flex Fuel 1 of 519 *RIP*
    Sep 11 2015
    Western Mass
    I'm going to give this one a go....06J-115-611E.....$15 on amazon , not a huge deal if it doesnt work
    Sep 22 2017
    TN
    Let me know if it works please!
    Sep 11 2015
    Western Mass
    Hi there, sorry for the late response, but the dip stick mentioned above fits perfectly on my wifes 2016 Q5 2.0T....and the pull handle part fits as well without having to be cut/trimmed or anything.
