Results 1 to 40 of 58
Thread: Cat removal
    Jul 28 2014
    New Milford/Danbury, CT
    Cat removal
    My pipe broke off the flange on my passenger side cat. I need help on how to lower the tranny. A lot of people have said that they let the tranny sag and wiggle it out. Would I need to support the engine from above? If so, why?
    I’m thinking of just supporting the tranny with a jack and letting it sag since I wouldn’t be touching any of the motor mounts.
    Can someone guide me through this process with any of their experience?
    Thanks in advance
    Jul 28 2014
    Apr 05 2016
    Portland, OR
    I've done it twice now. Once to gut the cats and once to replace them with test pipes after blowing the flange off.
    Assuming you don't care about the cats you can cut them out and it will save you from dropping the subframe.
    Only the passenger side is super tight, drivers side can come out without cutting.
    Anyway here is a quick run down:
    Remove the Exhaust and Downpipes
    Sag the trans by undoing the bolt that hold on the support. (put a jack under it before loosening the bolts then slowly lower it until you have enough space.
    Remove the secondary O2 sensors
    Remove the bolt from the support
    Remove the 3 bolts holding the cats to the manifold
    Cut the bottom of the cats off
    Wiggle the cats out
    If you don't want to cut them you will need to support the engine from above and drop the subframe.
    Geoff
    Oct 31 2015
    Quote Originally Posted by whiped View Post
    Wiggle the cats out
    How many hours of labor is this once the exhaust and downpipes are removed?
    Apr 05 2016
    Portland, OR
    We did it in about 4 hours both times. (Our time, shop time like like 8 hours?)
    The second time we also installed a few other parts and ate lunch.
    It's a pain in the ass to do
    Geoff
    Oct 31 2015
    Thanks! Will get my installer to try this method (I’m dsg).
    Established Member Two Rings denako's Avatar
    Jun 29 2016
    Chicago, IL
    Geoff, if one doesn't want to go the test pipe route, what do you recommend for gutted cats to avoid the flanges breaking off over time? Re-weld the support around them before throwing them back in?
    11' S4 6MT / 03' GTI 24v / 97' 318i
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by denako View Post
    Yeah if you reinforce the welds you might be fine.
    Honestly, I'd just do test pipes. Even if they are the cheap chinesium ones.
    Geoff
    Jun 29 2016
    Chicago, IL
    I wanted to keep the gutted cats more so for the feedback I've heard with sound. Supposedly gutted cats have a lot less rasp and dB level then test pipes? Maybe you can chime in on this since you've had both at one point.
    Apr 05 2016
    Portland, OR
    Gutted cats were for sure quieter.
    Test pipes are louder, deeper and in my case drone less.
    If you are only worried about sound add mufflers downstream to reduce it.
    Geoff
    Oct 31 2015
    By the way how much room is there to work with under this method? Looks like installing test pipes is fine but is there enough room for hfc’s which will be smaller than oem cats?
    If dropping the subframe, what are the high level instructions from beginning to finish? Will install this Monday, thanks!
    Jun 25 2017
    nashua NH
    Quote Originally Posted by Chibo View Post
    i just did this this past weekend on my dsg car , its really easy , i did not drop the subframe either , just drop the whole exhaust , remove the x brace , undo the 02 sensors (from the top) remove the trans mount / remove the 2 bolts from the drive shaft bearing / let trans hang down , pull out the cats , drivers side is easy , pass side i had to cut the bottom cat flange off and thats it ,, took about 4 hours ,
    2015 daytona grey S4 -nappa leather - alum optics - carbon atlas trim - APR stage 2 ecu and tcu tune apr charger pulley jhm 187mm crank pulley-apr cps - 034 trans and diff mounts - VMR 801 19x9.5 - luft carbon intake - ecs 2 piece rotors -macan calipers-red stuff-034 brace -h&r oe springs - bilstien sport shocks -cr-15-ledfogs-ecs rear carbon diffuser-ecs front carbon lip -rs4 steering wheel -rs4 shifter -jhm v2 test pipes- custom hfc downpipes with magnaflow x-pipe resonator -corsa exhaust
    Mar 20 2018
    Hanover, Maryland
    Anyway direction on install of spacers once test pipes already installed?
    Veteran Member Three Rings uponone nogaro's Avatar
    Sep 13 2011
    01 Silver S4, 00 Noggy S4 Sport Package, B8.5 Dsg S4 Dual Pulley,240sx w/2j swap
    Bay Area CA.
    Was there added power felt once cats where gutted or test pipes installed
    Senior Member Two Rings finnicky7's Avatar
    May 21 2017
    Detroit, MI
    Bring this one back from dead, but did you use a lift? Sawsall for flange cut?
    2015 S4 Prestige Volcano Red DSG AEM 2 stage W/M injection EPL 104 Tune, EPL TCU Tune, OEM TB, Jokerz Chaos Ported Blower, AMS Alpha Performance Boost Cooler, EPL 57.6mm SC Pulley, 189mm DP, HPFP, Walbro 255 bucket adder, Roc-Euro Intake, 034 Billet Drivetrain & Subframe Mount Kits, P3+TrackPack, RSE Test pipes, 034 Resonator Delete
    11.3 @122.95
    Senior Member Two Rings kashanova's Avatar
    Mar 11 2011
    Bronx, NY
    I added Eurocode test pipes, resonated DPs and the AWE touring exhaust and I have zero drone. It's a little on the loud side but at least there's no drone.
    Mar 20 2015
    McKinney,TX
    Quote Originally Posted by finnicky7 View Post
    I'm in the middle of doing this, bought a $30 angle grinder w metal disc packs at Harbor Freight to cut
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    how are you guys dealing with cel that comes on for the CAT's are you just using o2 spacers? if so which ones?
    Veteran Member Three Rings 03redgti's Avatar
    Dec 20 2010
    lancaster, pa
    Quote Originally Posted by chaos2984 View Post
    Vibrant straight spacers on amazon are they way to go. The j spacers sometimes get cel's sometimes don't but the vibrant straight never do.
    2013 S4 | Glacier White | Chestnut Brown Interior 1/13 | Sport Diff | IE Stage 2 | IE Intake | JHM V2 Test Pipes | PLM V2 HE | Custom Magnaflow Exhaust | Solo-Werks S1 | Rohana RF-2 20x10 square | Continental DWS |
    Senior Member Three Rings KLX's Avatar
    Jan 28 2018
    Shaw AFB SC
    Quote Originally Posted by kashanova View Post
    I had JHM test pipes on the same touring exhaust, and the drone and smell was too much, how is the exhaust smell on your setup...??
    2021 S5 Premmie SB 034 intake & springs/034 Stage 1
    2018 S5 Prestige SB Sold
    2015 S4 B8.5 APR Stg2 DP Sold
    @businessklazz on Instagram
    Mar 11 2011
    Bronx, NY
    Quote Originally Posted by KLX View Post
    It's been cold so I haven't had the windows down at all. I haven't really noticed anything smell wise but I've only had it on for three or four days.
    Sent from my Pixel 3 XL using Tapatalk
    Jan 28 2018
    Shaw AFB SC
    Copy that, down south it's 60-70 degrees, so most of my travels I have the windows cracked, but at stop lights it's was noticed..
    Mar 11 2011
    Bronx, NY
    I'm trying to find a way to add the cats in the downpipes, I'll let you know how it goes.
    Senior Member Three Rings EAFLO88's Avatar
    Dec 08 2016
    Texas
    Does anyone know of a method to apply the spacers for the o2 sensors while the test pipes are on?
    Veteran Member Four Rings maty360414's Avatar
    Oct 13 2015
    SoFlo
    Quote Originally Posted by EAFLO88 View Post
    from the top 30 minutes
    '13 S4 | EPL DP E40 | EPL TCU | AEM W/M | Tampa Ported S/C | 75mm TB | JHM 187 | MercRacing HX/Divorced | Becker TestPipes | AutoTech HPFP | Roc Euro Intake | BFI Engine Mounts | ECS Trans Mount | ECS F/R Diff Mount | H&R Super Sport Springs | 034 Rear Sway Bar | CR-15 | Drilled & Slotted Rotors | StopTech SS | Vertini RF 1.3 | Indy 500 | Sport Diff | BFI Shift Knob | Quattro Grill | ECS Spoiler/Diffuser | RS4 Bumper | J-Code | CWA100 |
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Quote Originally Posted by maty360414 View Post
    How the heck do you squeeze in that tight space? Been rollin with a CEL for like 2 years lol
    Sent from my SM-G965U using Audizine mobile app
    Nov 23 2018
    Ontario Canada
    I wanna know how the hell you unbolt the exhaust, I had to lower the entire thing when I removed my engine, the back side nuts that are against the transmission are a nightmare to access from the silencers and the cats
    Dec 08 2016
    Texas
    Really? Geez, I’d pay to have someone show me a quick video getting to them from up top!
    Oct 13 2015
    SoFlo
    I have ninja hands
    Veteran Member Four Rings raudiace4's Avatar
    Nov 06 2013
    2019 E63s, 2023 M3CX, 2018 SQ5
    Northern Suburbs, IL
    I had O34's test pipes to stock DPs, and Awe touring on my first S4. This was in 2013 and there were very limited options when your cats died, the drone was so bad that I hated driving the car. It was unbelievably loud, just ruined the car for me. I'd do anything to avoid test pipes on these cars.
    YMMV. Also heard if you wrap the Test pipes and down pipes in heat wrap it dramatically reduces drone. Some of you guys might want to try that, I wonder if ceramic coating would help too.
    2019 E63S PTG1000 | Blackboost | RWCarbon | Signature Forged | RedStar
    2018 SQ5 | H&R | RocEuro | Wagner Tuning FMIC
    2023 M3 Competition Xdrive
    Gone:
    2012 S4
    2013 S4
    2014 E63
    2016 S4
    2017 C63S coupe
    Mar 12 2012
    2011 Audi Q5 2.0t (Wifeys Ride) 2001 Audi S4 Stage 3+
    Can I resurrect again! Quick post as I keep searching for my answer.
    Just got my xs exhaust with 3" dp and test pipes going to 2.5" true dual. It came with one o2 sensor extension but I though you need 2 at least.
    Am I right? Do I need to install 2 so I don't get a cel? Or all 4? Or is 1 enough and where is the best place if 1 is enough?
    Sent from my SM-N960U using Audizine mobile app
    Veteran Member Three Rings SSSSS5's Avatar
    Apr 16 2018
    '85 300TD, '85 500SEL, NA MIATA, Merkur XR4Ti, '99 Cactus Avant, '10 S6, GX470, '16 Outback
    Bangor. ME
    I'll assume you have a 6 spd. I have the auto ZF trans and tried this method. It definitely helped with o2 removal and visibility, but no way I could pull them from above, not enough room in my 2013 s5. I was able to pull my cats whole, from below after lowering the trans, dropping my subframe, and ratchet strapping the trans over. What a chore. Had to pull the drivers side one through the wheel well.
    -Casey @CaseyCactusV10 | 1999 Cactus Green B5.5 A4 Slicktop + V10 + 0A3
    Oct 13 2015
    SoFlo
    Quote Originally Posted by SSSSS5 View Post
    I have a DSG, I have thin hands so I got it done all from the top
    Apr 16 2018
    Bangor. ME
    WOW! didnt drop the subframe or trans at all? Looked impossible to me without brute force and a 3lb sledge from above.
    Oct 13 2015
    SoFlo
    Wait lol I was talking about the O2 sensor not the whole cats sorry for the confusion
    Apr 16 2018
    Bangor. ME
    Ohhhh yeah, that I can agree with you on! Made the o2's a cakewalk
    Registered Member One Ring Only_a_V6lol's Avatar
    Jan 19 2020
    Sanford, NC
    What setup do you guys use for getting the nuts loose from the manifold so the cats can come off? This crap is kicking my ass, and I’m kinda just needing to pick some brains to get a handle on the situation
    Senior Member Three Rings BlackJon's Avatar
    Mar 07 2018
    If your not First, your Last- Ricky Bobby😏
    Philadelphia, PA
    I think I may need to figure out what I want to do with my car, I went dual pulley with IE Tuning stage 2 crackles but I think its starting to smell just a little. What are my options?? In case they do go?? Thanks guys
    Drive It Like You Stole It
    Veteran Member Four Rings JACKAL's Avatar
    Mar 28 2017
    Infiniti QX70S, Indian Scout Bobber
    Southeastern Wisconsin
    Quote Originally Posted by BlackJon View Post
    You can gut your cats or put on test pipes. Gutted cats tend to have a little less drone and rasp than test pipes. If you go this route, you should reinforce the flange welds as they are prone to cracking. You can also keep driving and monitoring for signs of the cats either blowing out (in which case you luck out and don't need to bother with a challenging removal and re-install) or plugging. Plugging obviously has the potential for engine damage though, so you are running a risk.
    B8 Sprint Blue S4 | 6MT | 034 Motorsport Stage 2+ E40 (3.40 PR) | Tampa Autosports Ported Blower | AEM Water/Meth 1000cc | Test Pipes | CTS Turbo Downpipes | MF 11385 | AWE Touring | Injen Intake | 75mm Ported TB | Merc Racing HX | Stoptech 6 Piston BBK | Stainless Brake & Clutch Lines | SB Stage 3 End. Clutch | Eurocode Short Shifter | D-Steering Wheel | Autotech HPFP | 034 Motor Mounts | Low Kick Spoiler | RS Bumper | Verde V99 19x9.5 Wheels
    Junior Member One Ring luxmatic's Avatar
    Feb 02 2019
    2014 S4, 2018 Clubman S ALL4, 2006 Mini Convertible S, 2016 E-Golf, 2003 Jetta, 89 MR-2 SC
    Oakland, CA
    Cats on my car are also showing signs of failing (silver dust in tailpipes, sounds deeper than it usually does, and feels slower), towing the car to a buddy's place to gut the cats tomorrow morning. Parked the car at home as soon as I noticed as I don't want to risk damage to motor if it is a clog.
    Fingers crossed it'll go smoothly, will report back with results
