I am getting to the final steps of having my 2.7t motor ready to drop into my b6 swap and I have upgraded my intake to run the 034 85mm MAF housing and their silicon intake for the housing. Being that the intake doesn't have the bung where the stock vacuum line taps into I need to just run between the IM and the booster connection on the firewall and am wondering what parts/pieces/hose sizes/check valves people have run to accomplish this. I'm at work writing this so i don't have the measurements on hand but i believe the nipple on the IM is 21mm O.D. and the connection as the firewall is 14mm O.D. if i utilize the fitting that plugs into the rubber grommet. I also have a spare green check valve that I thought i might be able to use. Just wanted to see how some of you have set this up. pictures appreciated also. Thank you.
