After over a year of looking for a set of replacement low dust daily pads and a set of track pads, I found the iSweep brake pads sold by Neuspeed.
http://www.neuspeed.com/352/4/0/3568...ads-front.html
Got them installed this morning and they’re a perfect fit! I wish I took pictures throughout, but I was too excited.
I spent a good part of an hour trying to take the pads out without taking off the caliper, finally accepted that I couldn’t.
Instructions:
1) remove wheels
2) use the back end of a hammer (nail puller) to compress the pistons to give yourself some room to work. I pried from the ends of the pad against the rotor, you can only get to the outside pad, but that should give you enough wiggle room.
3) use a punch (or flathead) to remove the bracket
4) using a 22mm socket, remove the 2 bolts from the back of the caliper
5) wiggle the caliper out
6) remove old pads
7) clean! I used dawn dish soap to wipe down, and a dry cloth to dry it up
8) compress inside pistons, I used my thumbs
9) install pads, take note, there’s 1 pad that the pad sensor connects to on the passenger side
10) reverse process
I followed some instructions on bedding the pads, hard braking is equal or better to the oem pads and no squealing.
I’ll update later on brake dust.
Ordering IS3000 pads so I can start hitting the track.
