Originally Posted by
NickLim
A lot of cars have the crackles and pops as well as flames on their tune with modern with cars
Just collecting information - I personally think flames out the back would be cool with a supercharged engine
- - - Updated - - -
If I get
https://roc-euro.com/products/roc-eu...-intake-system do I also need to order an air filter?
The kit includes the filter. You get the same thing by simply removing the top from your stock air box. If you want cool air, (cold air is denser than hot air and carries more oxygen molecules), a closed air box, CAI, will give you lower intake air temps. That's exactly what you have now. A better tube between the box and the throttle body and a higher flowing filter optimize your intake and also let you hear the supercharger.
If you just want noise (with no improvement in flow over stock with a drop in high flow filter upgrade) to match the exhaust farts you are seeking (if you can find a such a tune), yeah, just get the Roc-Euro. I think most of the serious performance guys moved away from that intake a long time ago after doing some comparison flow and temperature studies. Nothing "wrong" with it from an engine safety stand point, though.
Did you actually go over to the S4 thread and read about the intake options, what works and what does not? I'm guessing the answer is "no."
FWIW, the Roc-Euro intake does come with its own filter.
Finally, before you order that intake, have you checked Roc-Euro's website for fit? They are saying it does not fit your car, if I am reading this correctly.
https://roc-euro.com/collections/int...-intake-system
Might want to read the disclaimer and then contact them directly for fit. Just a thought . . .
