Originally Posted by
Bshiau
There was just enough room to get my right hand in the space to the right of the filter housing after cutting a couple zip ties. I used a stubby flat screwdriver to get the plug off. The latch on the plug will be by your thumb, and remember to push the screwdriver toward the sensor before you pull to release the catch on the plug. After that, a 24mm deep socket with a short 3/8 drive extension, and you are done. It took me an hour to confidently identify the sensor location, but only a couple minutes to replace it. Good luck and remember to be patient. This was much easier than the single pin which youÂ’ve already done.
Oh my goodness this was difficult on my 2014 S5 Cabriolet 3.0T.
To start, it's near impossible to see the connector. I used a scope camera to find it. It's roughly in the center of the engine, about 6" down, parallel to the driving direction like mentioned.
However, my connector latch mechanism was not on my thumb side (top), it was on the bottom. Also I had one of the latching connectors which made it near impossible to take off. My connector was 8k0973702D if you wanna google it. I managed to get it off by duct taping a cut nail to my finger, which gave me juuuuussst enough poking ability to open the bottom-facing red lock mechanism.
Also there was not enough room to get in a ratchet, so I ended up using a swivel connection with an extension to force it open.
Fortunately, I did finish the job in under 2 hours, but it was rather miserable haha. When I reinstalled the new sensor, the connector mechanism was now on the top (much better design), so they must've changed that in one of the iterations. (The valve I removed was 06E919081C, and I replaced it with 06E919081G).
Overall, thanks to this thread, you made this job much easier!
