Hey guys,
So my current repair project is getting my repaired Bosch 5.7 ABS Module re-coded. It's the original and ended up having bad components relating to the wheel speed sensors and brake pressure. It never had any VAGCOM connection issues with it. The car is a 2002 Audi A6 3.0 Avant Quattro with 1LF brake package and an Auto trans (not CVT).
I've studied and reviewed the procedure and have used the provided Ross-Tech wiki to build my login and coding #'s but the short of the long is this: I can login but the module won't accept the code. In VCDS, after inputing the appropriate code#, I end up getting a "login lost due to dropped session" in the upper right corner. I also have a Foxwell NT510 scantool with VAGCOM on it. It will report a successful login, however the code portion reports "code rejected".
I've been informed that the Ross-Tech wiki info is not 100% accurate and I might not have the correct code. If this is the case, IDK what the hell to do because I was never able to get my original code off the module before I sent it off.
According to the wiki my login should be: 07397 with a code of 06497 for a 2002 A6 (non-armored), 1LF brakes, V6 3.0 gas, Auto (non cvt).
I feel like i'm so close to getting this crap fixed. Between time and money, I'm pulling my hair out. The only conclusion i've found online was another forum member, with the exact issue i'm having, had to purchase a new module and then the coding worked. I hope this is not my fate as most new Bosch 5.7's I've seen online cost anywhere from $700-$1000+ which is insane. I'm already about $300 in, toward this repair.
I deeply appreciate any usable insight.
If useful, here is the portion of the VCDS autoscan:
VIN: WAUVT64BX2N089073 License Plate:
Mileage: 137314 Repair Order:
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
Address 01: Engine Labels: 06C-909-559-ASN.lbl
Part No SW: 8E0 909 559 D HW: 8E0 909 059
Component: 3.0L V6/5V G 0003
Coding: 0016752
Shop #: WSC 02325 785 00200
VCID: 3664FD9A42DC3DF103-5072
2 Faults Found:
18057 - Powertrain Data Bus
P1649 - 008 - Missing Message from ABS Controller - Intermittent
16805 - Warm Up Catalyst; Bank 1
P0421 - 001 - Efficiency Below Threshold - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4B0 927 156 FF
Component: AG5 01V 3.0l5V USA 1213
Coding: 0001002
Shop #: WSC 04940 001 00001
VCID: 70E80B82603853C119-5000
1 Fault Found:
18158 - Supply Voltage
P1750 - 003 - too Low
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 H
Component: ABS/ESP allrad 1728
Coding: 00000
Shop #: WSC 00000
VCID: 26442DDAC27C4D71B3-5072
2 Faults Found:
01044 - Control Module Incorrectly Coded
35-00 - -
00778 - Steering Angle Sensor (G85)
66-10 - Not Matched - Intermittent
