Originally Posted by
OlePokey
So I know this is an old thread but I also know there isn't much out there because people basically are told its impossible or you'll just end up fucking up your lense which both may be the case all varying in each case but here are a few instructional videos on how to separate the housing and lense when sealed with permaseal which I believe most b8 s5 models used and I'm sure many more but you get the idea.
*If you watch there's a video where the guy uses a special solvent combined with the heat that makes easy work out of it. After watching all 3 that's what I'm gonna go with . Everything else is straight forward like any other headlight but the key is the tools and the exact temp. Then "chisel" away at the seal. But headlight chisel not sledgehammer and iron chiseling stumps in half.
https://youtu.be/i7GAbiS2-rs
https://youtu.be/2B-ODfzqbyk
https://youtu.be/sG27LKxCHI0
@olepokey. Firstly, I've not done this.. But...As a fellow tinker, you might be thinking about a better tool for the job at hand.
Assuming we are dealing with thermoplastic, any high-speed tool will fail because the hole seals up with hot shavings as it moves along. Thus a cutting tool must operate below melting point, or any shavings need to clear instantly.
Option 1 then is a wicked blade on the trusty corded Dremel with a nice flow of water to cool and wash out the kerf. Needs to be a thin blade so the fitment is not altered and only a small amount of plastic disappears. I was going to suggest a diamond blade, but that is probably not aggressive enough. Maybe the 1.5 inch diameter 60 tooth steel blade.
You would also need a good jig to steady the saw and headlamp under a little stream of water. The saw can buck like crazy and leave a bloody mess. Good news is that the idea can be tried on a sacrificial part like the extra mounting tabs or something.
So that's the conservative version. Given sufficient time and resources, I would love to experiment with the plastics version of a plasma torch. The 50 amp arc is, instead, a 5 watt 405 nm blue engraving laser head (100 bucks on amazon), and the tip gets fitted with vacuum instead of compressed air. Beauty of the cutting laser is that it has a short focal range. Outside of the sweet spot it throws one heck of a beam but it's not concentrated enough to damage a car part.
Well, that's my two cents. I hope you take the shot. Good luck!
