[QUOTE=Neil F;14928794]Locksmith companies can program fobs (Note it you have one, don't forget to have the plastic emergency key programmed)
Thanks for your post, but as I wrote elsewhere, I question if the keyfob was programmed at all. More likely IMO is that locksmiths can add the key's unique key number to the list of keys for the car. For my BMW I purchased a kit called the AK90+ Key Programmer to add a bmw key.
https://www.amazon.com/Qiilu-Program...9803714&sr=8-5 One can also use software to add a key, but the software method is a little more difficult or expensive IMO. But it wasn't how I did it so I don't know much about that method.
My Qs are,
Q1: Is there a similar key programmer for AUDIs?
Q2: Is there a similar software program?
Q3: What's the name of the physical module dealing with security in the 4F=C6 platform? For my BMW it is called the EWS module. They go for $15 used. You can program them by ODBII or removing the circuit board and using the kit on the chip that holds the key list. The German cars are typically very similar, so I'm guessing Audis do the same thing.
