Results 1 to 9 of 9
    Aug 14 2017
    Plymouth, UK
    Electronic parking brake warning on dash, but it still works fine
    Had this issue for a good year or so now but figured it's time to try and figure out the cause.
    The warning comes up approx 5-10 seconds when I turn the ignition on, whether or not I've disengaged the parking brake yet.
    Both the motors work on the callipers and they hold the car find. Any ideas what might be causing it? One possible theory I have is voltage drop due to my air ride also turning on but no idea how to combat this if that is causing it, anyone else running air had a similar problem?
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    Check your brake fluid level. Might be low.
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Aug 14 2017
    Plymouth, UK
    That is a damn good point, I hope it's something that simple!
    Established Member Two Rings S4_V6T's Avatar
    Jan 24 2013
    Dunfermline/Fife/Scotland/UK
    Quote Originally Posted by Carllavis View Post
    Maybe try the ABS wheel speed sensors. I replaced all of mines recently as was getting the same message along with a few others (headlight warning, parkbrake malfunction). It resolved the issue.
    Have you performed a scan to see if any codes are present?
    Hope that helps a bit.
    Veteran Member Four Rings Poodini's Avatar
    Oct 26 2015
    2016 Subaru Outback 2.5 Limited
    Fremont, NorCal
    Without having a VCDS scan, it could be any number of things. Have you tried engaging it when you’re parked? Does the lever continuously blink or stays solid red once the epb finishes extending the piston.
    Jack the rear up and pull rear wheels off. Spray some brake cleaner & Inspect both epb motors and electric cables for any signs of damage. If it looks ok, check the cable connection to the epb servo. Try unplugging, clean, and reseed them to ensure they hadn’t somehow loosened.
    After all that, try enabling the epb and listen if either side is possibly not working. Then try releasing them and recheck. If everything looks good, then yould have to look further upstream for a possible electrical short. This is where a Ross-tech cable comes in so handy so if you don’t have one, either get one or find someone local who does. It’ll save you time/energy trying to sort it out as to possible cause.
    ** Of note: our epb system is run via a control module. Keep in mind that said module is also responsible for a couple other things so should the module itself or one of the other things it’s regulating is the problem, then it may not even directly be an epb issue. That’s why an autoscan is key.
    Aug 14 2017
    Plymouth, UK
    The brake itself functions as expected, both motors work and hold the car fine, solid red light on the leaver when the brake is on, no light when it's off.
    Managed to scan it with Carista and it came back with parking brake: 00576 terminal 15
    Oct 26 2015
    Fremont, NorCal
    If Carista uses the same coding reference as Ross-Tech, then your issue might be here:
    http://wiki.ross-tech.com/wiki/index.php/00576
    Were there any other codes present, even if unrelated? Is anything else electrical wise affected?
    Aug 14 2017
    Plymouth, UK
    Only other fault that came up was
    Infotainment system
    03276 testing management software version
    Oct 26 2015
    Fremont, NorCal
    Odd.
    So it’s pointing to a possible electrical short. Other thing you can check is your fuses. Beyond that, you might have to take it in for a thorough look see.
