Results 1 to 28 of 28
    Dec 14 2017
    Windsor, ON
    Wheel lug torque spec
    Shop installed my AG M610 wheels today. I believe they torqued them to 100 ft/lbs. I'm wondering what is the exact torque spec for when I re-torque them? Also, the oem tire pressure spec of 41 psi seems awfully high. Is that what I should set them at? Thanks folks.
    Senior Member Three Rings tominabox1's Avatar
    Nov 08 2017
    DFW
    between 80 and 100 is fine.
    2014 A4 Quattro // Sport Package, Black Optics, Bang and Olufsen
    IE Stage 2, CR-15 Strut Brace, USP High Flow Cat, Spulen turbo inlet pipe, aFe filter
    Oct 14 2012
    Empty...for now...
    SE PA
    I typically torque mine to 88 lb-ft and have never had one come loose - however, I do check / re-torque after ~50 miles or so of driving. I think most shops go heavy on seating torque knowing that 98% of customers would never go back in 25-50 miles to re-torque the bolts.
    I usually keep my 19" tires at 38 psi.
    SOLD 2015 Daytona Gray S4
    May 20 2010
    IIRC, 90 lb-ft is the spec. I usually hit 95 on mine.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    90 ft lbs is what I use and as mentioned above, I recheck the torque after a bit of driving (same or next day). And as a PSA, if you're running aftermarket wheels with conical bolt seats, be sure to keep a set of 5 of the OEM ball-seat lugs in your trunk in order to attach your spare wheel/tire in case you get a flat. Do not use conical seat bolts to attach the spare wheel - it requires ball seat lugs!
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Jul 16 2012
    Mid-Atlantic
    OEM recommendation of 6.7 quarts of oil seems awfully high. Is that what I should actually use?
    Also, can't take the time to google what type of gas I should use, or read the manual, can u guys assist? Thx in advance.
    2014 S4 - APR Stage 2 - APR CPS - AWE Touring w/ Resonated Downpipes - APR Carbonio Stage 2 Intake - Alu Kreuz - H&R Front and Rear Sways - 034 Inserts - Focal KX165 + Audison Bit4.9 + Audison 4D - Xpel Front End Wrap - Modesta BC-04 Paint Coating - Rayno S9 Tint - R8 Oil Cap - Porsche 911 Coolant Cap - CR15 Strut Tower Brace - Q5 Brembo Brakes - Goodridge Stainless Brake Lines - P3 Gauge (w/ Track Pack)
    My Seller Feedback Thread - http://bit.ly/2vD36PE
    Veteran Member Four Rings theweebabyseamus's Avatar
    May 12 2008
    OEM tire psi on normal load is 39/33, or 32. Cant remember exactly. 41/41 is for a full car (5 adults) or towing.
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    I think 88 ft lbs is factory spec
    Sent from my S9+
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    Quote Originally Posted by Works2shoot View Post
    7.2,quarts when you change oil filter.. I use 93 octane top tier gas. Although only 91 is required
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Feb 26 2014
    2019 Ford F-150 XLT zfgRacing 93 tune. 1986 Ford Mustang Gt t-top 76mm turbo
    New York
    Quote Originally Posted by theweebabyseamus View Post
    Psi for tires is 36F/36R, full load is 41F/41R and wheels lug torque specs are 90ftlb, enjoy...
    Established Member Two Rings mercedesinfarct's Avatar
    Jun 13 2017
    Philadelphia
    the spec is 90. It's in the manual.
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Quote Originally Posted by Moogas1 View Post
    I find 39/37 to be good for my PSS's, with just myself in the car most of the time.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Feb 26 2014
    New York
    Quote Originally Posted by sacandagaD View Post
    I’ve run those pressures as well. I’m just reiterating what the sticker on the door jam says. Currently I’m using Bridgestone RE71Rs on my 18’s and running 36 because it’s a more aggressive tire and it works well. On my all seasons I run the pressures you’re stating and it’s perfect for those tires.
    May 06 2015
    Minnesota
    Owners manual says 39/33 for normal load conditions with 255/35/19 and 41/41 for "full load condition". I've been running 39/33 and getting good tire wear but as most will tell you, it doesn't hurt to play around a bit and see what fits your driving style best.
    2013 Estoril Blue S4 - gone but not forgotten
    2014 SQ5 - gone but not forgotten
    2015 Mini Cooper S
    2021 Hyundai Santa Fe
    Veteran Member Four Rings Silver Streakin's Avatar
    Mar 05 2004
    B8 S4, 17 Expedition EL, 2009 328ix coupe
    NoVA
    It was 89 ft lbs with my B5, 7 and I’ve used that for my 8. (No owners manual)
    Tires ... no way I’d use that low (low 30s) in the rear.
    2011 S4, 6M, BB/panda, Sport diff, ADS, B&O | UniTronic stage 3 Dual Pulley | MercRacing HX | RocEuro intake | AWE Track & DPs resonated | H&R c/o w/Bilstein B8 rears| 19" VMR 710 & 19" Peelers | 034 trans insert | AK brace | CR15 bar | DEVAL CF Diffuser
    SOLD 2007 S4 DTM, Phantom Black Pearl, manual | JHM | FI | H&R | VMR | 034
    RIP 2001.5 A4 1.8TQMS, Silver/Ebony | APR stage 3 | STaSIS Tracksports | StopTechs
    SOLD 1995 90
    Feb 26 2014
    New York
    Quote Originally Posted by MN Blue S4 View Post
    Cool...
    Dec 14 2017
    Windsor, ON
    Thanks folks. I just verified with the owners manual. Torque spec is indeed 90lb/ft. Tire psi for normal load is 36f/33r and 41/41 for fully loaded. The sticker in the door jam only says 41/41 and that's what the shop set them to. Boy it was a bumpy ride back home lol..
    Mar 28 2016
    Quote Originally Posted by B8S42011 View Post
    39/33
    Dec 14 2017
    Windsor, ON
    Quote Originally Posted by hilmar2k View Post
    39/33
    Perhaps that is for the 18" wheels. For 19", I am certain it is 36/33.
    Established Member Two Rings mdwalsh20's Avatar
    Mar 05 2017
    Colorado Springs/CO
    Not sure why this is always some debate... straight from the owners manual for 19” 36 front 33 rear.
    Junior Member Two Rings p951's Avatar
    Oct 09 2013
    Calgary, Alberta, Canada
    Quote Originally Posted by mdwalsh20 View Post
    From the 2013 owners manual. 39/33 for 19”
    Dec 14 2017
    Windsor, ON
    Well there you have it. Different years, different specs. I wonder why that is.
    May 12 2008
    What year is this manual for?
    Mar 05 2017
    Colorado Springs/CO
    2012... I always wondered why tire places had different specs than what my manual said so I always made sure to specify. I’ve forgotten before and when I got the car back I could definitely tell a difference even with it only being 3-4 psi higher. Wonder why audi felt that much of a change was needed since there isn’t much difference between the two as far as weight goes.
    May 12 2008
    I can understand the 3-4psi, I can tell a little difference from 41 down to 39. Maybe I’ll bring mine down to 36 and see how it goes.
    Mar 28 2016
    My 2014 manual also calls for 39/33. Obviously they made a change, as the newer cars have a different spec. Maybe they had issues with the lower pressure? I'd be inclined to run the higher even if I had a '12 or older with the lower spec in the manual.
    Established Member Two Rings nowakm99's Avatar
    Jan 21 2018
    2016 Audi S4, 2012 Cayman S, 2025 Integra Type S
    Toronto, Canada
    Quote Originally Posted by LYKUNO View Post
    Thanks you for this tip. Didn’t think of it!
    2016 S4: IE Stage I, IE CAI, AWE Touring Exhaust, CR-15, H&R Rear Sway bar w/ Moogs end-links, 034 Motorsport transmission mounts, Vorsteiner V-FF 103s in Machined Titanium
    Jun 03 2011
    X1, 1M, S4, M3
    KS
    Not sure where jygesq got his info but oil fill capacity with filter change is 6.6 quarts. Pg 284 in owner's manual, 2011 S4.
    '11 S4 Sprint 6sp sport dif
