Results 1 to 25 of 25
    Rest in Peace Four Rings EURO_DOLL's Avatar
    Jul 22 2011
    Long Island, NY
    RNS-E iPhone Integration Options
    I know there have been threads on this, but I haven’t found a straight answer, and most of the modules have been discontinued.
    What’s everyone using for iPhone integration in the RNS-E? When I had my Symphony II in my last B6, I used a Dice electronics integration kit, but looks like they’re unavailable for the RNS-E.
    Bluetooth isn’t a necessity, but would be nice. Just need the ability to hardwire into my iPhone 7 Plus, stream music, and preferably something that charges at the same time.
    TIA!
    BOOBS& BOOST
    Current: Bagged 04 B6 A4 1.8T | Bagged 2017 MK7 Golf R
    Past: 03 B6 A4 3.0 Quattro
    Bagged 02 B6 A4 1.8T FWD
    14 MK6 Jetta
    Static 94 Corrado SLC
    15 Golf TDI
    Instagram: @boobsandboost
    Veteran Member Three Rings Euston's Avatar
    Oct 10 2016
    AudiB7S4Avant
    Yuma, Arizona
    Subscribed.. I installed my RNS-E into my b6 Avant yesterday and almost bought a Bluetooth Module but I’m interested in what else is out there
    Jan 04 2014
    US
    sub’d.
    just bought the RNS-E recently. also looking for the BT integration
    B6 04' A4 1.8TQ 6MT
    Oct 10 2016
    AudiB7S4Avant
    Yuma, Arizona
    I got the Aux cable that plugs into the back on the unit and I got the A3 faceplate which has slightly curved edges on the top corners so the Aux cable comes out of there nicely. Then I got my usb charger for power...
    Veteran Member Four Rings ApexIt's Avatar
    May 28 2008
    2005 A4
    I ran an aux cable for a year before I decided to really look for a bluetooth option. I eventually settled for one of these. It's relatively cheap and works quite well. The only thing I had to do was run a wire to the fuse box for power. It's been running strong for 4 months now and I much prefer it to the aux cable. The only downside is you cant take calls using it, it only does streaming.
    As a side note, this one looks to not need any additional power wires and should connect to the factory harness.
    There used to be a seller on Amazon that sold a unit with a microphone for hands free calling that had great reviews but its no longer listed there. Unfortunately all of these solutions omit charging. Its not a big deal for me though since I dont need to charge my phone when driving. If Im on a road trip I just use my usb charger.
    RS4 Rear Sway :: KW V1 Coilovers :: B5S4 Calipers :: W&L Catalytic Converter :: 30% black tint :: S4 Door Blades
    Oct 10 2016
    AudiB7S4Avant
    Yuma, Arizona
    The aux in Bluetooth Module looks good. Apparently you an use the Mic that comes installed in the roof console. Although I don’t know how to do this, anyone that’s done it please chime in.
    Is it a vagcom code issue?
    May 28 2008
    2005 A4
    Quote Originally Posted by Euston View Post
    I think any aftermarket bluetooth module that gets installed needs the harware and firmware to support hands free calling. I dont know how easy it would be to use the stock microphone and wiring with aftermarket bluetooth modules.
    I think it would just be easier to buy an aftermarket module that comes with a microphone and wiring and run it all up to the location of the stock microphone.
    Jan 24 2008
    Pennsylvania
    I use the OEM bluetooth module for telephone use, and also have the OEM AMI glovebox module for streaming music and charging. Works pretty good overall, music streaming with 3rd part apps like Spotify can be a little quirky, but it works.
    This is fully functional with MFSW as well.
    2021 GMC Sierra AT4 Diesel
    Gone but Never Forgotten:
    Instagram: bluewings460
    Jan 04 2014
    US
    Quote Originally Posted by Turbavanttro View Post
    can you share the link or the parts number ?
    thx mate.
    B6 04' A4 1.8TQ 6MT
    May 28 2008
    2005 A4
    Quote Originally Posted by uzone02 View Post
    thx mate.
    Not sure how recent the information is on this thread, but it should be enough to get you started. Do keep in mind that the stock bluetooth module does not support A2DP (the protocol that allows music streaming).
    Oct 10 2016
    AudiB7S4Avant
    Yuma, Arizona
    Yes please share. Anyone out there have the non-Bose audio in their car and have a Bose rnse? What module do I need to power/amp the front speakers?
    May 20 2010
    Dension BT Pro
    Harness is plug and play and will let you stream your music. Also you can use USB sticks, in case you want an alternate source (e.g., passengers). Had one of these in my B7 and it was great.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Jan 04 2014
    US
    Quote Originally Posted by ApexIt View Post
    so what about RNS-E mk II ? also noA2DP?
    B6 04' A4 1.8TQ 6MT
    Jan 24 2008
    Pennsylvania
    My setup:
    RNSE: 8P0 035 193 G
    Bluetooth Module: 8P0 862 335 B
    See the thread below for info on which AMI modules will work, and some related topics you may want to consider. I don't have access to the part number of my AMI but there are specific versions that work properly while others don't.
    I chose this particular setup because I wanted an OEM solution.
    https://www.audizine.com/forum/showt...ooth-streaming
    Jan 24 2008
    Pennsylvania
    There are no OEM bluetooth options that support A2DP in the B6/7, FYI. You either need to use a third party solution, like tune-2-air, or use OEM AMI and stream with the phone plugged into the AMI.
    May 28 2008
    2005 A4
    The RNS-E does not contain any bluetooth hardware. Bluetooth hardware/connectivity comes from the bluetooth module that is a separate piece of hardware.
    Feb 12 2008
    Michigan
    I ran an auxiliary cable from headphone jack to back of radio and the sound quality was less than sub par. I think this is what I replaced it with, the sound is great, loud, consistent and it charges the phone and works with any music device. I plug my phone in under the center arm rest
    http://enfigcarstereo.com/ENFIG_AI2_IPDU_AUX.html
    Jul 14 2009
    Pasadena
    dension gateway pro BT. the end all solution. done.
    IG: @matthewee
    Apr 24 2017
    Kansas City
    I’m using a Grom Audio unit. Can connect via Bluetooth or through usb (also charges through usb)
    16' A8L Sport 4.0L V8TT
    05' S4 6MT Moro Blue - Sold
    01' A4 5MT 3.2L - Sold
    Oct 10 2016
    AudiB7S4Avant
    Yuma, Arizona
    Is there such a module to power front speakers in a Non-Bose car with BOSE RNS-E
    Feb 17 2004
    Liberty Hill, TX
    the front speakers are powered by the head unit in a non-Bose setup. The head unit is the same either way.
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Oct 10 2016
    AudiB7S4Avant
    Yuma, Arizona
    Quote Originally Posted by Matt Devo View Post
    So with that being said, my front speakers should work regardless which rnse?
    They worked just fine with the symphony 2 but nothing after I plugged in BOSE rnse
    Feb 17 2004
    Liberty Hill, TX
    yes, there's no such thing as a 'Bose RNS-E'. did your RNS-E adapter harness have the brown 8-pin connector for the front speakers? Is it coded properly for a non-bose setup?
    Oct 10 2016
    AudiB7S4Avant
    Yuma, Arizona
    It does have the brown connector.
    I didn’t mean BOSE rnse, the seller told me it came from a Bose equip Audi.
    I got to take it out again because the aux cable is no longer working.. it did before I installed it in the car. And now since it’s installed properly, it no longer works so I’ll check the brown connector again
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    I would highly recommend a plug in universal bluetooth unit. They're much cheaper and work flawlessly. Some have noise cancelling which works great. Literally less than $20. Some for $15. It'll bring in calling and music streaming for a fraction of the cost of "add-ons". You won't have audio control through steering wheel or head unit...also won't have phone charging capabilities, but honestly you'd only get 0.5-1 amp which is useless. Also, one benefit of using one of these universal ones is that they support the latest compression codecs. Sound quality will be much much better.
    https://www.amazon.com/SoundBot-SB36.../dp/B00RH29CJO
