07 2.0 was at the dealer this past week to get the airbag recall done and they mentioned it could use a new VCG. Install looks simple enough, but was curious if anything else needs to be replaced at the same time? Saw a kit that came with new bolts and a gasket for the PCV which might get but wanted to double check if those were wear items. Also, what involved with changing the chain on the tensioner? I've done the gasket on a 1.8 but not sure how bad it is on a 2.0.
