So I purchased a '09 A6 3.0T 135k miles on it. Previous owner states car was never overheated but coolant low light came on, no signs of coolant on ground. I checked the dipstick and there is without a doubt coolant in the oil. Things I've done:
- Ran compression test on 6 cylinders, all equal to each other (no blown head-gasket)
- Removed and pressure tested Superchager for intercooler leaks (no leaks)
- PCV system looks dry from above and around it, I have not removed it to verify any leaks under it. (Should I?)
I've heard there is an oil cooler separate from the normal radiator that could be a source for oil and coolant to mix, is there any other point I'm missing?
Should I remove the PCV system to verify it's not cracked or leaking?
Basically what else should I check?
